Finding Tongue and Groove Bits
| Posted in Tools for Home Building on July 30, 2002 05:26am
I am working on a set of Walnut doors.  I have milled and planned most of the pieces down to 5/4 -6/4 thicknesses.  My planed finished thickness it between 1″ and 1.125″.  I have been unable to locate a tongue and groove set that can accommodate this thickness.  I can only locate sets for 3/4 thick boards.
Does anyone know a source of larger sizes?
Thanks in advance for your help.
  1. vasalesman | Jul 30, 2002 06:31pm | #1
    Are you looking for a plain T&G set or cope & stick?
    Al
    1. PaulCKing | Jul 30, 2002 08:24pm | #2
      Thanks for the quick response.
      I believe T & G.  I'm not sure what Cope and Stick is.... please educate me.  I will use a router/shaper table with the bits to create joints between the door pieces.  All the joints will be hidden.
  2. jet | Jul 30, 2002 10:42pm | #3
    Try http://www.leevalley.com/wood/page.asp?page=46178&category=1,46168&ccurrency=2&SID=
     These are all the panel rail and stile bits they have or just try their home page at leevalley.com and surf around.
    1. PaulCKing | Jul 31, 2002 05:05pm | #4
      There catalogue only shows bits with a capacity for 3/4" stock.  Still need help!  Thanks.
      1. bill_1010 | Jul 31, 2002 06:17pm | #5
        unless you set up your table saw and router and make passes, youll have to look to a shaper.  Pretty much with a 3/4 to 1inch spindle for the size you want.
        There is a product that turns your table saw into a moulder head. Its purple and has lots of attachments/cutters  Dont know the name offhand but google.com would help
        1. PaulCKing | Jul 31, 2002 07:44pm | #7
          I believe I have found the answer thanks to my problem thanks in part to your responses and to customer support at http://www.Leevalley.com - even though did not carry what I wanted they did a little internet research and sent me the following link.
          http://www.internationaltool.com/amanawedgetonguegroove.htm
          Thanks for your help.
          1. PaulCKing | Jul 31, 2002 07:52pm | #8
            Found two more sources of bits that meet my needs.
            Thanks again for your help.
            <http://www.internationaltool.com/freudadjustonguegroove.htm>
            <http://www.routerbits.com/cgi-routerbits/sr.cgi?1028134018_27595+103>
      2. vasalesman | Jul 31, 2002 09:02pm | #9
        Didn't get a chance to check my catalogs last night.  I did get one a while back though that had what you're looking for & made a mental note I'd never seen that bit before.  I'll try again tonight.  BTW, my earlier reference to "cope & stick" is another term used to describe rail & stile cutters.  More accurately, it describes how rail & stile cutters shape the material.  Generally, plain T&G cutters are formed with right angles.  This would be the type usually seen on T&G flooring.  T&G is often combined with a v-groove for ceilings, walls, and some flooring.  Cope & stick is mirror image decorative profiling that lets the end of the rail meet and interlock with the edge of the corresponding stile.
        Al
        1. Piffin | Aug 01, 2002 05:03am | #10
          I was just looking at Tools of the Trade mag and saw an ad for Frued that said they have a set with adjustment washers for all sizes.
          BTW, Some flooring t&g bits have a relief on the bottm side of the groove about 1 or 2 dergees so that the top side ccan fit tighter.Excellence is its own reward!
          1. vasalesman | Aug 01, 2002 01:49pm | #11
            Yeah, I saw those on the Freud web site also.  I'm still scratching my folicly challenged upper deck though because I can't find the place that had the matched pairs that were for specific thicknesses.  So many tool catalogs & so little time but I'm in it for the principle now!
            Al
  3. Noidea | Jul 31, 2002 07:40pm | #6
    routerbits.com has a router bit to bulid window sashes and mullions.  It is made by Whiteside and costs around $80.  I have several Whiteside bits and they are fine tools.
