fine or course thread for metal roof
ponytl | Posted in Construction Techniques on November 21, 2009 06:31am
Ok got my 168ft x 20ft carport/covered parking structure welded up… cleaned, primed and painted… now i have to skin the roof…
it’s 6 bays 3 spots per bay… 8″ Z perlins 5ft o/c didn’t buy one piece of new steel… only new thing (purchased off ebay) are the the 56… 3/4″ x 5″ redheads that anchor the posts to the slab… I had all the beams posts and all but 4 of the Z perlins (my buddy with the scrap yard donated the last 4)
the roof skin is called “barn master” i think… each sheet covers 36″… i have a stack in my warehouse of 16ft sheets and a stack of 8ft sheets… so with overlap and overhang I’ll use one of each for each run…
now… I’ll use the self drillng screws with the rubber washer to screw down the roof… but what grabs better the fine thread screws or the course thread screws… i can get either…. and is there any reason to get anything longer than say… 3/4″? looking at about 25 screws per run… x 56 runs so 1400 screws… give or take…
so does it matter course or fine thread?
p
    Sphere | Nov 21, 2009 06:51am | #1
    Fine goes into steel, coarse into wood.
    PROUD MEMBER OF THE " I ROCKED WITH REZ" CLUB
    1. ponytl | Nov 21, 2009 07:08am | #2
      the screws i usually use... are course... self drilling... but they have a fine thread version... I think usually the fine thread are for when you are attaching something to thicker metal... like maybe over 1/8" thick? but which holds better/less likely to strip? light gauge to light gauge?p
        Sphere | Nov 21, 2009 07:14am | #3
        still fine thread, they don't backout as quick.Spheramid Enterprises Architectural Woodworks
        Dam_inspector | Nov 21, 2009 02:50pm | #5
        A fine thread screw will have a whole thread or two in thin steel, while a coarse thread will have less than one whole thread, it doesn't hold.
  2. caseyr | Nov 21, 2009 07:54am | #4
    I used some stainless steel self drilling screws from McFeeley's on a project. They worked pretty well, although I did actually predrill a small pilot hole. Similar to these
    http://www.mcfeelys.com/product/K43-0806/8-18-x-34quot-410-Stainless-Steel-K-Lath-Self-Drill-Screws
    Also used some of these to put planks on a trailer (used 2" long but too lazy to find the actual screw...):
    http://www.mcfeelys.com/product/H63-0810/8-18-x-1quot-316-Stainless-Steel-Hex-Self-Drill-Screws
  3. Piffin | Nov 21, 2009 03:12pm | #6
    metal purlins?
    Coarse if for wood substrate/underlayment, fine is for metal.
      Sphere | Nov 21, 2009 03:33pm | #7
      Same as Drywall, er, piffin screws on metal studs.
      wow, Piffin, studs and screws in one sentance,Well I'll be banned.Spheramid Enterprises Architectural Woodworks
      1. Piffin | Nov 21, 2009 03:42pm | #8
        That's a fine bit of punnery, but a coarse thought
