Finish air nailer for plywood ceiling
| Posted in Construction Techniques on July 16, 2002 06:13am
I have a project where I need to attach 3/8 inch sheets of plywood to the ceiling (faux T&G plywood) and I’m wonding if it’s appropriate to use my finish air nailer for the job?  I have a PC FN250a that uses 16 gauge nails – my thought is to use construction adhesive as well as the nails; any thoughts?  Thanks; Lance
  1. KenHill3 | Jul 16, 2002 07:07pm | #1
    Hi, Lance-
    In my opinion the adhesive is overkill for the ceiling. And I don't like to rely on finish nails for this application. My own preference is to use 1/4" crown staples- for the 3/8" ply I would use 1 1/4" or 1 1/2" long staples. Set them with the staple width running parallel with the grain- they will countersink very cleanly without blowing out the top veneer layer.
    Ken Hill
    1. LanceVBuren | Jul 16, 2002 07:56pm | #2
      Ken - Thanks for your help (sounds like a good excuse to buy a stapler!)
    JDRHI | Jul 17, 2002 12:49am | #3
    I dont think the adhesive is a bad idea, but I agree that the finish nailer aint yer best bet.
    If your talking about a porch ceiling, outdoor fluctuations in humidity will wreak havoc. Along with the adhesive I might recomend using a siding nailer.
    J. D. Reynolds
    Home Improvements
    "DO IT RIGHT, DO IT ONCE"
      JeffBuck | Jul 17, 2002 02:33am | #4
      Adhesive with sheet/ply goods is never a bad idea! While a stapler may hold a bit better.....the mechanical fastners are just there to hold till the adhesive sets.
      While staplers may hold a bit better.......I'm guessing your 16g nailer would work just fine...as long as the depth is set right and checked often. I know my 15g nailer does just fine.  Jeff   She's exotic ,but not foreign, like an old Cadillac......she's a knockout!
  3. DHambley2 | Jul 23, 2002 03:15am | #5
    Lance,
    I agree with jaybird. When reading your post my first thought was to use a siding nailer. If you don't have one, get one on ebay for $200. After i did my siding, I found hundreds of uses for a siding nailer.
    Darrell
    1. LanceVBuren | Jul 23, 2002 03:15pm | #6
      Thanks for the heads up; however, I did buy a Stanley Bostitch stapler (SB 150 sx) and it did the job for me.  I decided to use construction adhesive as an extra measure to ensure a quality job and no call backs.  Also, the advice regarding "stapling with the grain" really helped a lot; I shot one against the grain and created quite a blemish...
      1. Mooney | Jul 24, 2002 02:41am | #7
        atta boy !!!!!
        Tim Mooney
Two Ways to Test Windows
  • The New Old Colonial
