I am getting ready to run a lot of trim. Mostly casing for 6 doors. but also a jamb for a passage way, a split jamb door, some baseboard, and shoe.
This is about 4 times the amount of time that I have installed at anyone time.
So I go the DeWalt compressor and gun kit.
It has a #18 brad (5/8 – 1 1/4″) nailer.
And a #16 finish nailer (1 1/2 – 2 1/2).
The casing is common 2 1/4″ colonial and 3″ baseboard with 1/2 x 3/4″ shoe.
I got 2″ finish nails for the casing into the studs and for the baseboard. I figure that gives me at least 3/4″ into the stud.
And 1″ brads for the shoe and the casing edge into the jambs.
That sounds like enough holding power to me. But never using a nailer before I am not sure.
I could get some 1 1/4″ finish for the casing into the jamb, but leary of blowing out the edge.
If there any place that need pulling in then adding a couple of hand driven nails.
And probably a couple into the split jamb door.
Also with the nailer is there anyway to put something up temporary so taht it can easy be adjusted. In the past I have use hand drive and just put the nail in about half way.
how thick are yur materials yur nailing up....
WOW!!! What a Ride!
The base is 3/8"The casing if 5/8 for the part that gets nailed into the stud. And about 5/16 for the part that is nailed into the jamp.
3/4" for the 5/16....
2" for the 5/8...
1-1/2" for the 3/8... 1-3/4 to 2 is more better..
3/4" for the shoe..
all nails / brads / pins to be placed slightly off of perpendicular...
temp nail with 5/8 placed few and far between...
Thanks.It looks like I can get by with just the 1" and 2". But I will also pickup some 5/8" brads for tacking..
that slightly off of perpendicular is random directional as in up - down - left - right and a random mix there of...
on the base you should be able to hit the base plate but if ya think hitting a stud is in question counter angle two nais near each other..
A Tile floor has been added. In the bathroom there is some tile that comes down about 2 1/4" from the tile. So I will have to rip some of the BB down to fit.So I may or may not get into the plate.The place is a missmash. It had a fire and a repo (don't know the order) and it was being rehab, but the owner/rehabber got a job out of town and is moving..
got it..
clinch nailing it is at approx 12" centers...
16 is pushing it...
while yur at it think of nails as a "T" profile... cross grain them when ever ya can...
estimate a 50% gain in how many nails you'll use...
Bill, we temporarily tack stuff up with a nail shot through the fat end of a cedar shim. When you're ready to remove the piece, tug the shim, the nail stays put with head about 3/8" proud. Then use the shim to cushion the trim from your pulling hammer.This method is not always viewed as temporary, we've had painters caulk and paint the shims in<G> Winterlude, Winterlude, my little daisy,
Winterlude by the telephone wire,
Winterlude, it's makin' me lazy,
Come on, sit by the logs in the fire.
The moonlight reflects from the window
Where the snowflakes, they cover the sand.
Come out tonight, ev'rything will be tight,
Winterlude, this dude thinks you're grand.
What's the reason for slightly off perpendicular?
I usually shoot finish nails based on the easiest way to hold the gun. If I get too close to the inside edge of the casing, there's a risk of splitting. Otherwise, I haven't had any problems.
Use the 2 1/2" for trim in the bathroom. Anything shorter won't reach the copper or pex in the walls. 8)
awwwwwwwwww paaaaaleeeeeezzzzzeeeeeeee!!!!!!!!!!!!!!!!!!
you know yur suppose to use that Bostich trim nailer that punches 3 inchers...
since the nails crush their way in splitting is limited if yur using the right sized nail...
the little bit of angle tends to hold the piece yur nailing on better...
Did you hear me smack my forehead as I said, "oh, of course!".
