finish joints on OSB interior.
pitchfork | Posted in Construction Techniques on February 3, 2007 04:43am
Howdy, I’m new here, I have been putting my time in finishing the insides of a new pole barn/shop/garage. I am using OSB to finish the walls. This building should be heated in the immediate future. Any suggestions on what to use to fill in the joints? Will drywall compound
work loose, if I didn’t heat the building one winter? That seems the easiest to finish and prep before I paint.
Thanks.
  1. rez | Feb 03, 2007 04:46am | #1
    Greetings pitchfork,
    As a first time poster Welcome to Breaktime.
    In the situation you mention I'd trust a caulk instead of drywall paste.
    And a point to remember is not to use a latex primer on that OSB as it will begin to swell and lift the osb glue impregnated woodchips. An oil base like a Kilz type product is better.
    Cheers
    be you guys go easy
    Edited 2/2/2007 10:05 pm ET by rez
    1. stevent1 | Feb 03, 2007 05:38am | #2
      PF,
      Why do you want to fill in the joints? Any panel product properly installed should yield minimal joints.
      IMHO, a joint in a garage/shop is a good thing.
      (edit)Rez. I meant to send this to pitchfork.
      Chuck S.
      Edited 2/2/2007 9:43 pm ET by stevent1
    IMERC | Feb 03, 2007 06:01am | #3
    latex caulk....
    WOW!!! What a Ride!
  3. RobWes | Feb 03, 2007 06:16am | #4
    Leave it as is.
    Anything you do to it is only going to look like poop.
    IMHO if you wanted it perfect, it should have been rocked or been done in metal.
  4. Stilletto | Feb 03, 2007 02:10pm | #5
    If you don't want to see the seams,  put battens over them.  No more seams,  and it will never crack.
      bstcrpntr | Feb 03, 2007 02:39pm | #6
      You are now familiar with the carpenter and the box theory.  Which states: Tell three carpenters to build a box, all the same size, it will be built three different ways, but it will be the right size and shape you asked for.
      I would do the battens myself.
      Welcome to Breaktime....................careful, it is addicting.The bad news is you've done exactly the right things to be exactly where you are today.   "IdahoDon  1/31/07"
  5. Piffin | Feb 03, 2007 02:56pm | #7
    wow...
    OSB really bad choice here. A barn implies farm stuff = moisture inside. So OSB will swell and move. absolute no to drywall compouind for that. Use cualk or battens. Oil based paint to keep that moisutere from soaking into the osb so much. About five or ten coats oughta do it.
