Finishing a shed roof
PenobscotMan | Posted in Construction Techniques on July 26, 2006 10:20am
Asphalt shingle question:  How do I finish roofing a shed?  This is not a shed roof intersecting a steeper roof, but a free-standing stucture.  I’m thinking I need to install a strip of roll-roofing over the butt edge of the highest course of conventional shingles, so that the ends (apices) of the slots are covered.  Better than nailing on a series of loose tabs.  If that is the way to go, should I cement as well as nail?
  1. Piffin | Jul 27, 2006 12:07am | #1
    Here's what I do...
    I shingle until the first time the shingle course runs past the edge and cut the over hang off.
    Then I instal the metal drip edge that in other areas would be entirely under the shingles.
    Then I finish her off with ridge caps cut like normal but huing over the metal half an inch
    1. PenobscotMan | Jul 27, 2006 11:27pm | #2
      Thanks, Piffin, from your neighbor on Vinalhaven. I'll try that, and I'm sure it will look better than the roll roofing solution.
A Practical Perfect Wall
  • The New Old Colonial
