Finishing Basements & Insulating
onestep | Posted in Energy, Heating & Insulation on January 28, 2009 01:19am
I live in the Detroit area. I’m finalizing plans to finish my basement. One area of concern is insulating the perimeter 2″ x 4″ stud walls. I had planned on using R-13 fiberglass batts w/ a kraft paper vapor barrier. Those in the trades that I’ve spoken with say this is proper while others mention rigid or batts w/ no vapor barrier. Suggestions, please.
  1. MikeSmith | Jan 28, 2009 02:10am | #1
    1"   EPS  Performguard  against  the wall
    build  your  stud  wall  inside that..  with   a PT  shoe  on the floor
    insulate  your  stud  wall  with  dens-pak  cellulose
  2. JeffinPA | Jan 28, 2009 03:54am | #2
    Everyone  has an opinion but this is what has worked for me.
    Certainteed dry-rite insulation
    It is designed to adjust its permeability based on the moisture content of the spaces.
    The key is that you want moisture to freely move thru the space and if you trap it, it will end up condensating.
    I also keep the studs a couple of inches away from the wall with a dead air space (I run a strip of 1/2" sheetrock on the ceiling tight to the sill for firestop first) and keep the drywall up off the floor about 2" as well
    worked so far.
