finishing drywall
skip8208 | Posted in Construction Techniques on February 15, 2006 11:04am
I’m sure this has been asked before, I’m finishing a wall that I want to do something differant and creative with. I’d like to make it look textured,  without the mess and hassle of shooting mud with a gun. Could I add a little sand to the mud to duplicate plaster ? Or does anybody some creative ideas.
                           Thanks in advance. Skip
  1. Brooks | Feb 15, 2006 11:44pm | #1
    Try textured wallpaper. My wife used some with a two-color paint job that looks spectacular! And you can pull the paper if needed...
    1. skip8208 | Feb 16, 2006 04:25am | #3
      Thanks Brooks. I'll look into it.
  2. atrident | Feb 16, 2006 01:15am | #2
      My 50's house is done with...ground walnut shells. It's a little coarser than sand and impossible to match. You can get pearlite in a fine size that might work.
    I did what Brooks did in my Bathroom. Textured wallpaper,painted and let dry,then painted with another color and quickly and gently wiped the surface off with a firm sponge. This left a 2 toned 3D paint job.
    Edited 2/15/2006 5:21 pm ET by atrident
    Nuke | Feb 19, 2006 08:04pm | #4
    How about a pattern roller for creating embossed-like texture?
  4. JHOLE | Feb 19, 2006 08:35pm | #5
    Always wanted to do a roll-on coat followed with a random dob texture using dw.
    Could get interesting.
    Remodeling Contractor just on the other side of the Glass City
  5. chascomp | Feb 19, 2006 10:18pm | #6
    Mixing pre-mixed plaster with some water to make it slightly soupy you can create myriad textures. I've used a 3/4" or thicker roller and rolled the soupy mix onto the wall, then depending on the texture you want you can slightly flatten the resulting peaks with a flat trowel, or wait 'til the soup dries and either knock the peaks off, or sand them slightly flatter. I've matched the texture of old plaster in a century home that way. looks great. And by the way get an old sheet of drywall or plywood and practice, practice, practice.
    "God made fools so the rest of us would look smarter."
    Edited 2/19/2006 2:49 pm ET by chascomp
  6. Mooney | Feb 20, 2006 12:03am | #7
    What Brooks said or you can apply a skip texture with mud and fine sand troweled on the wall.
    Tim
Big Doors Have Big Challenges
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
