Finishing off Cement Backer Board
C1802362 | Posted in Construction Techniques on May 26, 2002 04:38am
I’m putting a new bathroom in. In the shower stall, I used Cement Backer Board for the walls and greenboard for the ceiling. I’m now ready to tile and realized the tile is only going about 6 feet up the wall, leaving the other 2 feet exposed backer board.
What’s the best way to finish off the non-tile area? Do I smear drywall compound over the CBB to give it a smooth surface. Suggestions welcome.
Art
  1. rez | May 26, 2002 05:15pm | #1
    Art-   I was curious as to the reasons for not continuing the tile on up to cover the backerboard?
    1. C1802362 | May 26, 2002 05:26pm | #2
      There's no reason why I couldn't. It would just be more materials and time....
    JDRHI | May 26, 2002 06:34pm | #3
    Yes, smoothcoat the exposed backer board with drywall compound, using mesh tape in wall corners and at wall/ceiling joints.
    J. D. Reynolds
    Home Improvements
    "DO IT RIGHT, DO IT ONCE"
    1. chiefclancy | May 27, 2002 12:19am | #4
      You can also cut out the backboard you won't be using and replace with drywall. Depending on the circumstances, you might find this easier than finishing the backerboard.
  3. wflather | May 27, 2002 04:27am | #5
    Wouldn't tiling the rest of it be easier and quicker than taping and skimcoating the exposed board?
    1. C1802362 | May 27, 2002 03:46pm | #6
      My wife also seems to have no problem with tiling to the ceiling, so it appears that it'll be the least amount of work.
      Thanks for the guidance
      Art
        JDRHI | Jun 04, 2002 12:05am | #7
        If your ceiling is not level, its going to scream at you every time you look at the tile cuts. (assuming you install the tile level)J. D. Reynolds
        Home Improvements
Choosing a Paintbrush
  • The New Old Colonial
