Finishing out a round window
| Posted in Construction Techniques on July 27, 2002 09:27am
I have been slowly building a small “get away/retirement” home on the Oregon Coast for the past 10 years.  I am finally ready to hang the sheetrock.  We have 4 -24″ round windows, and I would like some advice on how to case and trim them out.  I have thought about building a round template, and building up thin strips of wood till I have a 3/4″ thick round frame to fasten in the rough opening.  Any and all advice would be appreciated.
Max
  1. PhillGiles | Jul 27, 2002 10:22pm | #1
    While you can cut your own circular millwork with a molding cutter (or have a millwork shop cut some for you), or buy round casings from Outwater; the classic approach is to cut casing into small wedges (roughly 1" each), glue them up in a circle, then a little touch-up carving/sanding will produce a very acceptable round window casing.
    Phill Giles
    The Unionville Woodwright
    Unionville, Ontario
  2. Piffin | Jul 28, 2002 05:54am | #2
    If this will be paint grade, the easiest and least expensive way is to cut the circle casings out of MDF. You can use a router on a stick to get true radii. Then use the router to put a profile on it and slap it up. Use MEDEX for exterior grade if needed. I can often buy curved casings with the window from the manufacturer, too.
  3. Joe_Fusco | Jul 28, 2002 10:36pm | #3
    Max,
    There are always several ways to approach any situation. The factors that determine the approach can be time, money, equipment or general know-how. There was a good article in this rag about using two pieces of identical moulding to create a circle top casing. If you are so inclined then go for it. If not then buy it.
    Edited 7/28/2002 3:37:58 PM ET by J Fusco
  4. r_ignacki | Jul 28, 2002 11:19pm | #4
    if you do any wood turning, and are equiped, it would be like making a round picture frame.
    no turn left unstoned
  5. sdr25 | Jul 29, 2002 05:22am | #5
    Max, a few years ago I was met with finishing out an oval window. I took the easy route and finished it with a drywall return using plastic flexi corner bead.
    Scott R.
  6. vasalesman | Jul 29, 2002 02:10pm | #6
    If this is paint grade, don't forget Flex-Trim.
    Al
  7. User avater
    BossHog | Jul 29, 2002 02:14pm | #7
    You might check with the folks you bought the window from. The manufacturer might offer a trim kit for your windows.
    Teach a man to fish and you feed him for a lifetime. Unless he doesn't like sushi - then you also have to teach him to cook.
