I HAVE ROUGH CUT BLACK WALNUT. IT IS 18″ TO 5’3″ LONG AND 1″TO 3″ THICK. IT HAS SEASONED FOR THREE YEARS. THE THICKER WOOD HAS A TWIST. THE SHORTER (18″) CURLES UP TO 2″. ALL OF IT HAS A BOW. WHAT TOOLS AND METHODS SHOULD I USE TO TRUE UP THE WALNUT WITH THE LEAST WASTE. I”M PLANNING ON MAKING A MANTLE.
To prevent moisture buildup and improve performance, install a continuous air barrier—such as drywall or specialized membranes—under tongue-and-groove boards or other interior wall paneling.
I HAVE ROUGH CUT BLACK WALNUT. IT IS 18" TO 5'3" LONG AND 1"TO 3" THICK. IT HAS SEASONED FOR THREE YEARS. THE THICKER WOOD HAS A TWIST. THE SHORTER (18") CURLES UP TO 2". ALL OF IT HAS A BOW. WHAT TOOLS AND METHODS SHOULD I USE TO TRUE UP THE WALNUT WITH THE LEAST WASTE. I"M PLANNING ON MAKING A MANTLE.
