Firepalce Design Help
| Posted in Construction Techniques on December 14, 2003 05:47am
Greetings;
Me again.. We’re still building… I have selected a rumford firebox design for my realMasonry fireplace and now need some help on the design of the structure/chimney… It sure seems like this has already been done (like the Rumford box design) and I should be able to just go get it…
Thanks and Gid bless- Sluggo1
  1. fdampier5 | Dec 14, 2003 05:56am | #1
    your are correct it has been done,  so often that they make everything you need.  Back issues of fine home building show a rumsford fireplace kit, (I just lent my copy to the in-law so it'll be a while before it's back)
     the very critical element is the throat..  design it wrong and you have a dangerous smokey hunk of masonary.  what the kit does is provide you with the correct shape so that a proper venturi is created and the smoke will smoothly go up the chimney, radiating more heat into the room
      there is a very critical length, depth, height, formula to follow as well..
  2. RodBishop | Dec 14, 2003 04:36pm | #2
    http://www.rumford.com
    This site will tell you everything you need to know, and direct you to masons who build rumford designs.
    Also, look for "The Forgotten Art of Building a Good Fireplace", printed by Yankee magazine years ago. I believe it's now out of print so you'll have to do a bit of searching. Library, maybe?  Inter library loan? This book has all the measurements, angles, etc.
    Rumford fireboxes are great. There's nothing I like better than seeing and feeling a fire in a fireplace that I've built. A real sense of satisfaction.
        Rod
    PS   Check out the cover of Dec 2003 "house beautiful" magazine.  That's one of mine.
    1. RodBishop | Dec 14, 2003 04:39pm | #3
      Shameless plug, I know!
      http://magazines.ivillage.com/housebeautiful/subscribe/issue
        Rod
Versatile Vise
