My main floor will be on a poured slab with the perimeter foundation being a poured 8″ wall going down below frostline to a continuous footing. Centered along my gable end wall will be a fireplace, and the continuous wall footing will enlarge there to handle the fireplace foundation. My question involves the typical cantilevered fireplace base slab formed and poured atop the fireplace foundation. The cantilevered part is for the masonry hearth. Since my adjoining floor is concrete slab on grade, is it still a good idea to cantilever a monolithic fireplace base slab out, so that there is no slab joint between fireplace and hearth?
GEne,
As long as your main floor is supported at it's edge by the block and or poured concrete wall and the rest of the slab is on compacted fill you should not have a problem placing your hearth on the slab. The purpose of a cantileved slab is to deal with the problem of wood movement in a frame building by isolating the masonry from the wood. In a properly constructed chimney/fireplace the rest of the structure could burn down around it and it would still stand. In your case you are not placing the hearth on wood so you do not need to pour the cantilevered slab.
Mark
