Fireplace, Gas Logs & Valves
| Posted in General Discussion on February 19, 1999 07:50am
question: I am converting three fireplaces from wood burning to Gas. Heat
is not an issue and we want it as realistic as possible and as automated as
possible.
1) What are the top names in the gas log business?
2) Which give the most realistic look?
3) Are there differences in the valves and burners?
4) How are remote sets different than manual?
Please help
Thank you
Lloyd Hascoe
  1. Floyd_Hasco | Feb 17, 1999 07:10pm | #1
    possible.
    Please help
    Thank you
    Lloyd Hascoe
  2. Guest_ | Feb 19, 1999 07:49am | #2
    If you're looking for realism, you want a vented
    gas log. Some of the better looking ones are
    Rasmussen and Peterson. There is a lot of
    difference in valves. If you want a remote or wall
    switch, you will be looking at a millivolt
    control. Peterson offers a nice log with the valve
    concealed underneath the burner. Rasmussen uses an
    ITT valve that may be located up to three feet
    from the log, but it is really big and must be
    shielded from heat if it is placed inside the
    firebox. Millivolt valves can be hooked up to
    generic remotes such as Sky Tech (very nice). They
    may also be switched back and forth between wall
    switch and remote. No electricity is required,
    just a few batteries. Make sure you check out all
    your measurements and clearances before you buy a log set
  3. Floyd_Hasco | Feb 19, 1999 07:50am | #3
    possible.
    Please help
    Thank you
    Lloyd Hascoe
Picture-Perfect Pergola
