Fireplace grate
jyang949 | Posted in General Discussion on November 26, 2011 01:52am
The man who maintains our chimney said that we need to replace our log grate with one that is shallower and taller*. I haven’t found any locally–they’re steel, not cast iron, and the shallow ones are also too short and low. Will have to mail-order a cast-iron grate without seeing it first.
Do you know if Vestal’s cast-iron grates are a good quality? Or can you recommend another brand?
Janet
*Current grate is 24″×17″ and the logs sit 4″ above the floor of the firebox. The firebox is 47.5″ wide in front, 37″ in back, and 21″ deep.
  1. DanH | Nov 26, 2011 05:23pm | #1
    Nothing really wrong with steel vs cast iron -- it's the overall thickness (at the thinnest point) that's most important.  And if they're too short you can extend the legs with pieces of pipe..
    1. jyang949 | Nov 28, 2011 11:32am | #3
      Metallurgy questions
      The owner of a local fireplace store said that I could just decrease the depth of my existing grate by cutting off the prongs that point toward the back. "Go at it with a sawzall. It'll cut through eventually." But with that modification, the logs might roll up against the back wall of the firebox instead of leaving a 3" clearance.
      Perhaps the bend in the back prongs can be increased, which would effectively decrease the depth and still hold the logs. That would require annealing the prongs at the bend. I suppose the annealing temperature depends on whether my grate is steel or iron--is there an easy way to determine this?
      Can a propane torch heat the metal to annealing temperature?
      Janet
      1. calvin | Nov 29, 2011 07:33pm | #4
        janet-shim it out.................
        If the grate will catch the ends of fire brick, lay a couple of those along the back of you log holder.  That would eat up about 3 inches of the back (on edge).
      2. DanH | Nov 29, 2011 08:30pm | #5
        The computer ate my homework, er, post.
        A propane torch isn't hot enough to soften steel for bending.  A MAPP torch comes closer, but it would still be a challenge.
        Cast iron is trickier -- very hard to bend without breaking.
        1. jyang949 | Nov 29, 2011 09:18pm | #6
          London Bridge
          I'd forgotten: Iron bars will bend and break/ my fair lady.
          Janet
    MarkH | Nov 26, 2011 06:23pm | #2
    You may find a welder who will make exactly what you want.  It's an easy job.
Outdoor Lighting
