Firewood access door
toolin | Posted in General Discussion on February 6, 2007 05:49am
Thinking of putting in a firewood bin, next to my wood stove.
Wood like it to have an exterior door access so I can load it from the woodpile from the outside. It might be 3 ft high 3 ft wide???
Any ideas what kind of exterior door to use?? Want good insulation and
excellent weather seals?? I could build something, but if there is something available commercially I would probably go that way??
  1. peteshlagor | Feb 06, 2007 06:31pm | #1
    Be sure to put a bug zapper inside.
    1. DoRight | Feb 06, 2007 07:35pm | #3
      DITTO that suggestion!  Many, many spiders, ticks, ants, etal winter in the bark of trees and wood piles.  If you bring wood in the house just for the day's fire you don't ahve a problem since the wood is cold and as long as it stays that way the insects remain dormant and stay put.  Once they warm up in a multi-day storage location as the poster is suggesting they begin to run all over the place.
      1. JoeArchitect | Feb 07, 2007 01:23am | #7
        There's a movie idea!
        1. DanH | Feb 07, 2007 01:47am | #8
          "Firewood on a Plane"? Sorry, it just doesn't have a ring to it.
          1. JoeArchitect | Feb 07, 2007 03:34pm | #10
            How about "THEY CRAWLED OUT OF THE FIREWOOD"?
  2. JHOLE | Feb 06, 2007 06:36pm | #2
    Most steel / fiberglass door manufacturers wil cut down their doors for a small fee.
    Ends up just like a entrance door but smaller. - treshold, seals, jambs all the same.
    Obviously a special order. Talk to your supplier. Suprisingly affordable the times I have done it.
    Remodeling Contractor just on the other side of the Glass City
  3. DanH | Feb 06, 2007 07:41pm | #4
    Note that it doesn't have to have a threshold -- you can use a "door frame" on all four edges. You can even forgo the hinges and make it lift-out if you want, using screen hangers or some such.
    Or perhaps these guys: http://store.accessdoorsdirect.com/index.html
  4. dovetail97128 | Feb 06, 2007 07:49pm | #5
    What ever you choose remember to provide a good lock . I know of several home breakins that utilised the wood door for access.
    IMERC | Feb 06, 2007 09:51pm | #6
    use a ready made HVAC closet door... about 3'0x4'0...
    WOW!!! What a Ride!
  6. MikeSmith | Feb 07, 2007 03:26am | #9
    move your woodburner outside to a shed  and keep the damn firewood out of the house
  7. brownbagg | Feb 07, 2007 05:08pm | #11
    they make them,, I have seen alot of people with them, Its like a 2x2 steel door that goes to the front porch where the wood pile is.
