Firewood storage pass through door
alfie | Posted in General Discussion on March 26, 2009 11:46am
I am building a house with a fireplace, and next to the fireplace I am putting in a firewood storage “closet”. There will be an exterior door to load the firewood, which can then be lifted off and burned as needed.
Looking for ideas on pre-built doors for the exterior, or on making one myself. Approximate size would be 24″x48″.
  1. calvin | Mar 27, 2009 12:31am | #1
    I might peruse Entry Door companies and see what they can do for you $
    Maybe look at or contact  Bilco  the basement access door company.  They've got roof hatches, access doors etc that might work (with thought).
    http://www.bilco.com/
    http://www.quittintime.com/
  2. dovetail97128 | Mar 27, 2009 12:36am | #2
    What ever you use make darn sure it can be securely locked from the inside. Locking hinge pins if an outswing door.
    I know of a half dozen houses here that were burglarized through small firewood doors.
    1. alfie | Mar 27, 2009 12:39am | #3
      Thanks for the input.
      1. Snort | Mar 27, 2009 04:00am | #4
        If your wood storage is going to be covered, and over the door, an unbored and non mortised insulated fiberglass slab is easy to work. Local lumberyard should be able to get a sill/threshold, and weatherstripping. The jambs are pretty easy to make.http://www.tvwsolar.com
        I went down to the lobby
        To make a small call out.
        A pretty dancing girl was there,
        And she began to shout,
        "Go on back to see the gypsy.
        He can move you from the rear,
        Drive you from your fear,
        Bring you through the mirror.
        He did it in Las Vegas,
        And he can do it here."
        1. alfie | Mar 27, 2009 12:54pm | #6
          The door is in a 2x6 chase that is going to be sided. On the inside, the chase contains a zero-clearance fireplace, and the wood storage. The door I install will also be sided so it blends with the wall of the chase. The bottom of the door is about 3 feet above grade.Wood fed through the basement sounds great.
          1. junkhound | Mar 27, 2009 02:23pm | #7
            Is the fireplace just for occasional recreational use, or serious heating?
            If serious heating, go with a full size 36" wide door.  (been there, done that)
          2. alfie | Mar 27, 2009 02:41pm | #8
            The size is more or less defined by what is going on inside - I could add a few inches though. Intent is serious heating, though I have a feeling it will end up being somewhere in between recreational and serious.
          3. junkhound | Mar 27, 2009 02:56pm | #9
            We burned near 10 cords a year heating 5300 sq ft for close to 35 years.
            Only thing I can add for you on door size is I was tempted at times to install  double 40 inch doors so I could fit the backhoe bucket into the front room. When DW got to be over 60 YO, she started to rebel about 'feeding the fire'.
            My neighbor spends 5 days a week in his uninsulated garage and heats it with wood. Drives his small Kubota backhoe right up the stove.
            If your interior floor plan precludes a full size door, consider a thru the wall conveyor belt arrangement??  No idea right off how to weatherseal that well though.
          4. peteshlagor | Mar 27, 2009 03:20pm | #10
            OK, everyone else says it's OK.  I, from experience, wish to let you know this is a VERY, VERY STUPID idea.
            This wood you wish to burn, it is FULL of tiny hibernating insects.  Some, not so tiny.  Others, big fat spiders.
            As soon as you bring that wood in the house, the existing warmth will wake them up and they'll head for your wife.   No one else, only your wife.
            Now you tell me?  Would you rather have your wife refusing to sleep in the bug infested place?  Or some storage system that is still easy to access, yet outside your heating envelope?
            I found a spot right outside my the garage door.
          5. Dave45 | Mar 27, 2009 04:43pm | #11
            My thought too, Pete. I've seen at least a dozen termite infestations resulting from storing firewood in contact with a house, deck, or garage.
          6. cic317 | Mar 27, 2009 04:47pm | #12
            HUH, Only the wife you say... I think I just found a new project for the house! Let you know how it turns out!
          7. Scott | Mar 27, 2009 08:02pm | #13
            >>>only your wife.
            LOL.
            I knew there was a reason that I park one of these:
            outside on the deck, full of wood. We put the stove right beside the door.
            Scott.
            Edited 3/27/2009 1:04 pm by Scott
  3. dude | Mar 27, 2009 10:32am | #5
    saw a large house that had several fireplaces all fed from the basement
    each had a mini elevator that was loaded in the basement  & came up in a wood box next to the fireplace , different !
  4. jimcco | Mar 27, 2009 09:22pm | #14
    My daughters used to use the firewood box for house access when they forgot their keys. Also had a squirrel get in that way once.
    1. dude | Mar 28, 2009 03:59am | #15
      i get pallet cut offs from a local pallet factory for my fireplace and as their is no bark i get no bugs and very little ashes
       I only take the hard wood cutoffs < cherry ,oak ,maple etc about 5 cords a year
