First time home builder – have questions
verification justified
In the first pic I would be more concerned about what appears to be a gap in the wall sheathing than the short plate. If I'm seeing this right you have a really weak spot there.
Pic 2 shows a sheathing hole that's not too terribly ugly but the one in pic 3 is and for sure needs repair.
I think you do need to keep a close eye on the details of this job....
Thank you for the response. I'm definitely going to bring the sheathing gap up with the project manager. I told him I wanted do a walkthrough with him when he does his final frame check and I plan on pointing these things out.
I wouldn't be too concerned about the holes in the osb sheathing. While being unsightly and probably unnecessary, they really don't compromise the integrity of the structure. Though, in my mind, they do compromise the character of the contractor.
The wall gap looks like somebody blew the wall section measurments by 1/2". I'm not a professional builder or framer but when I've joined two wall sections on my own structures I always leave that sheet of sheathing off and add it after the walls are tipped up. This, to tie the sections together. That said, your situation still may not be compromising the structure. Is this in a place where two windows abut? If so, there's no shear capability in the wall here. If it is a shear wall, then you may have a problem.
In any case, when dealing with this contractor, I'd put all my concerns in writing and sent to him either in an email or hand it to him. Keep your tone light but be clear. Deal directly with your contractor or his designated rep. The framing sub doesn't work for you.. he works for the contractor.
Wall framing gap
As part of the building permit process, is there a scheduled framing inspection required? If seems to me the joining of these two wall sections is weak. You can see the nails are spanning the gap between the two wall sections.. Is the top plate overlapped at all? I would take lots of pictures and document what you have questions on let the PM know about your concerns. What type of warranty is available on the home and check the statue of limitations in the event of an issue.
Wall framing gap
That first picture concerns me for the reasons mentioned. Also, I'm curious as to whats going on in that section of wall. There are 8 studs there within 12-14 inches or so. Why? Sure seems that there'd be a lot of heat loss in that spot through thermal bridgeing. Maybe somethings going on there that I don't understand, but I'd ask about it.
that looks like dumb framing
got any pic of the exterior of this wall section ?
