So it happened. Used the window and door spray foam from Home Depot to seal around my brand new windows….It expanded. My windows are now bowed at the bottom and don’t form a seal when you close them. They are brand new vinyl double hung Weathershield windows. Please tell me there is a technique to fix and shut once again. I completely removed the foam but I think it was there for too long as it still does not seal when shut and locked.
Learn how to patch drywall above a fiberglass shower without totally redoing everything.
Doesn't answer your question, but you should always use "low expansion" foam around windows, especially lightweight ones. Yes, it's more expensive (because a can only goes about 1/4 as far) but it can save a lot of headaches.
yp
Well I definitely know that now. It didn't say it expanded on the bottle and said for windows and doors so my thought process was "why would they sell it if it expanded and said windows and doors" even though it wasn't specified.
no need to panic...
Is the sash itself actually bowed or just the frame?
Also, where and how is it bowed?
technical explanation
So I will explain this in technical terms....The bottom part that is not moving ( I assume this is the outside frame?) is bowed up in the middle/ I think it is maybe an inch raised. Therefore, when I close the window, it doesn't seal. Looks like it from the inside, but on the outside, the part that moved up and down, doesn't even touch the bottom.
I would consider driving 1-3 screws through the bottom of the frame and into the rough framing below. You'd want to plan it well, though, so that the screw heads sit flush and don't look too bad, and so that they're driven squarely enough that they don't pull the frame in/out, only down.
reply to panicing!
not quite sure the different. basically the part that opens and closes (up and down), when I push it down, there is a gap at the bottom.
post a picture. no offense but its hard enough to picture what the problem is with a proper description.
there is the window frame (the square/rectangle that the window sits in), sash wich is on the two sides (allows and guides the window as it opens and closes). if single hung then the top section if the window will be fixed and the bottom pane will slide up and down.
now, if the issue is when you close the window and you have a gap on one side (a bottom corner) and not the other you may have set the window out of saquare and the exesive foaming made it worse.
put it on the ground, measure corner to corner (diagonally), those measurements should be the same. if they are not adjust until they are. re hang.
He said he "completely
He said he "completely removed" the foam.
here it is
heat gun
L
The brickwork, that's not holding it up in the front is it?
If the windows are solid plastic, it's likely that the solvents in the foam softened the plastic and caused it to deform.
any suggestion
I definitely know it is now deformed thanks to my swift DIY skills. Any suggestions as to fix it, at least to the point where it may seal again?
First, determine whether, with moderate hand force on the frame, it can be forced down flat, and if in doing so it remains reasonably straight and true. If it won't go down at all then probably something is still blocking it. If it won't go down without twisting or some such the frame may be toast.
brickwork
I don't think it was in the beginning at least as the windows were in before the brick. Are you saying maybe the brick was done too high or something?
Dan
In new construction there can be shrinkage of the framing (in the width of joists). Sometimes enough that the brick veneer will push up on the bottom of window jambs. If not enough room was left between the brick, mortar and window, I've seen what you have occur.
how bout the history of this place? New construction home or addition?
do other windows show this problem?
is there room between the brick and frame for you to push down on that frame to straitened it out?
Even a hunk of hardened mortar can be enough to hold it up.
Can you post more pictures with details?
And you do have everything below the window removed, foam shims etc. Do these windows have nailing fins?
Additional pics
New construction. They're actually single hung not double,vinyl Weatgershield windows
It appears that the bottom frame members are very slightly bowed in the center. I'd consider 3 carefully-placed screws to pull the bottom down.
From the two pics
If there's no space between the top of the brick and the bottom of the window, the only way you're going to fix the problem is move the frame up on each end (straightening the sill). Near impossible if there's fins securing the window.
if new construction, where's the builder and the mason?
