fixing interior wall/floor framing
mnj | Posted in General Discussion on September 27, 2005 12:57pm
Hi –
I took a look at a project yesterday – remodel of a 900 sq ft shop into an apartment.  Two things became apparent –
    1) the exterior walls have sheet rock hung but not taped.  They are framed with  2 x 4’s  on 24″ centers.  That’s not good.    I’ll have to remove the sheet rock anyway – while it is off should I glue 2 x 2’s to the 2 x 4’s and call it good or insert extra 2 x 4’s for a min stud spacing of 16″???
   2) The floor looks like 2 x 6 joists over a 12 foot span.  Worse yet they are on also on 24″ centers.  The span table I have available gives a max span with 2 x 6 of 8 feet.  The sub-floor is one layer of 1″ x 8″ pine topped with a 3/4″ sheet of particle board (not OSB).   This seems bad, is it?
Mike
  1. rez | Sep 29, 2005 07:22pm | #1
    Greetings mnj,
    As a first time poster Welcome to Breaktime.
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
    Perhaps it will catch someones attention that can help you with advice.
    Cheers
    r u a feckless dastard?
