Flared Column
DennisT | Posted in Construction Techniques on November 8, 2008 08:00am
I’m not sure if this is the proper name: flared column? They’re a column that is similar to a tapered but instead of straight there is a decreasing curve from bottom to top (parabolic?).
Can anyone provide any hints or links to possible construction techniques for flared columns? I saw a small structure with some (wasn’t able to get pics) and I’m cosidering using them in an upcoming major remodel.
Forgot to mention – the columns I saw were stone wrapped which is the same as what I’m considering.
TIA
Edited 11/8/2008 12:01 pm ET by DennisT
  1. MikeSmith | Nov 08, 2008 08:04pm | #1
    maybe you are talking about classic greek columns... to make them APPEAR straight to the eye... they built in a slight curve..
    i think if you google on "entasis"... you will find the technical description
  2. john7g | Nov 08, 2008 08:08pm | #2
    you can look at columns.com or chadsworth and get some ideas.  Some of their stuff is pretty reasonably priced so before I sunk the time & effort into making one myself (even though it would be fun) I'd get a quote form them to see how much you're effort is worth.
    Sounds like you're looking for a Doric style but if you research the classical style and columns on Google you ought to find the proper proportions for dia vs ht.
    1. DennisT | Nov 08, 2008 08:21pm | #3
      Thanks for the feedback, but that's not what I'm looking for. Here's something more like it:
      http://www.jeffkerber.com/gallery/categories.asp?nameID=28Look at the chimney for the fireplace, specifically the stone portion. Envision that but with the curved tapers on all four sides and used as a structural element instead of a typical tapered/roman column.
  • Townhouse Transformation
