Hi everyone. How would you go about flashing Aluminum clad wood casments with board and batten siding?( B and B over 1*6 strapping over sheathing) Would you still use a head flashing and how can you make it look reasonable with 1*6 trim? Are there advantages in setting the nailing fins on the boards or set the windows onto the plywood sheathing and recess them? Thank you.
Listeners write in about shower panels and cordless tools and ask questions about old wiring, air leaks, and gutter covers.
One way would be to set the flange to the outside of the boards, then use 5/4" boards for trimming it out ( or use 3/4" trim and then use 1/2"or less battens). Caulk the trim to the flange as you install it. At the head trim, use a bead of caulk at the top too, and then caulk at the outside of that joint.
A lot depends on your climate and the amt. of overhang you have on the roof - in other words, how much water is likely to hit it. If the windows are pretty much right out in the stream of rain, I would recess further back into the wall with the flange on the sheathing to water proof traditionally and use a very thick trim.
"The first rule is to keep an untroubled spirit.
The second is to look things in the face and know them for what they are."
--Marcus Aurelius
I don't like horizontal trim with B&B - a scheme that negates the strength of the design by giving water a place to get between wood surfaces at the bottom of a watershed, cross grain movement between board and trim guarentees caulk failure eventually - if under a sheltering eve, you can get by with it, secure flashing to furring behind board -
a suggestion: set the the window frame first (actually, flash under the window and then set) so that it will end up even with the outside of the board, nail a board up on either side of the window, attach flashing to furring/nailers over window, rip/space boards to fill space above window leaving them to die slightly above the flashing with a 45* drip cut at the bottom - use battens to trim from board to window at the sides, batten above window with battens also drip cut at the bottom @ 45* (these should extend below the drip edge as tho the 45* of the boards were extended with the battens)
a nice minimalist scheme that uses the strength of the componets to shed water -
