flashing for metal siding
gamblewood | Posted in Construction Techniques on August 5, 2007 09:52am
I’m looking for tips on flashing vinyl windows for vertical steel siding.
  1. Piffin | Aug 05, 2007 10:24pm | #1
    what brand and style siding?
  2. Piffin | Aug 05, 2007 10:26pm | #2
    and are these replacement vinyls or with installation flanges?
  3. bigal4102 | Aug 08, 2007 12:43am | #3
    I installed J channel on the bottom and sides of my windows, with the side pieces stopping even with the top of the window, and running long past the piece of J on the bottom.
    Standard z bar on top of the window, overlapping the J on the sides.
    The bottom corners can be troublesome if you don't have a good WRB, under the steel.
    Edit... I didn't put the window wrap on, until after the bottom J channel was on, so the widow wrap lapped over the bottom J channel.
    A medium to large guy named Alan, not an ambiguous female....
    NOT that there is anything wrong with that.
    Edited 8/7/2007 5:48 pm by bigal4102
    1. fingersandtoes | Aug 09, 2007 08:13am | #4
      Wouldn't you have been better to put the wrap on before all the J flashing except the head flashing?
      1. Piffin | Aug 09, 2007 01:41pm | #5
        Yes he would have been.Looks like this is another one of those great threads where the OP forgets to participate...;)
        1. bigal4102 | Aug 09, 2007 07:19pm | #7
          On the head flashing... These windows, weathershield Aluminum clad casements, had a built in drip cap, that was sealed under the wrap, then I added a piece of Z in the desired trim color to match the J around the windows.I should take pictures, I am awful at trying to explain this stuff.A medium to large guy named Alan, not an ambiguous female....
          1. Piffin | Aug 10, 2007 01:20am | #9
            I was thinking it was at the bottom flange that you were taping with lap wrong way. Sorry.
      2. bigal4102 | Aug 09, 2007 07:14pm | #6
        I fear I did not explain that well.I have steel wainscoating that stops at the bottom of the windows. The Z-bar that capped the wainscoat was installed tight to the sides of the windows at the bottom, then a piece of J directly under the window, then the side peices of wrap lap down over the Z ,and J. There is no wrap on the bottom flange of the window, and no caulk under the flange. I am an amatuer for sure, but after much study here , I was trying my best to think like a raindrop.The op does seem to have vanished.A medium to large guy named Alan, not an ambiguous female....
        1. fingersandtoes | Aug 09, 2007 10:11pm | #8
          No need for pics. I understand now. No water into your house = happiness.
