Flashing poured concrete step foundation
Henley06 | Posted in Construction Techniques on November 8, 2023 01:46pm
Hi all,
I’m looking for suggestions on how best to flash the vertical edge of a poured concrete foundation. My thought is a custom bent aluminum flashing as we plan to have a drip edge type aluminum flashing and the bottom edge of our siding but the vertical aspect has been more challenging to try to determine what’s best.
Some additional information that may be relevant is we are using tyvek over the OSB sheathing,  Cor-A-Vent SV-l3 and Sturdi strips for a rain screen behind Ward spruce vertical grain clapboard siding that we primed with exterior latex wood primer on all sides.
  1. Wally3433 | Nov 08, 2023 09:03pm | #1
    Consider using Zip Liquid Flash. Some builders use this on the whole plate. It certainly will work for the foundation drops.
    https://www.huberwood.com/zip-system/liquid-flash?ref_=maas_adg_C2329DF2E7A0FF4D00CDB5F228BC8258_afap_abs&ref=mm_d3380136-534c-438a-b052-61968f54e587&gad=1&gclid=Cj0KCQiAgK2qBhCHARIsAGACuzn0EwdXh2YimEf2GXSm-W6CjUc97mGy19rPgUrUvc8lxOcLRRPbIIIaArmHEALw_wcB
    1. Henley06 | Nov 10, 2023 12:06pm | #2
      Thank you, Wally3433 I appreciate your input!
Beat the Heat: Cool Innovations
In this time of weather extremes and power disruptions, it's important to learn from the past as we think about the future.
