Flashing with Vertical Siding
| Posted in General Discussion on June 4, 2001 06:19am
Hello All,
I’m in the process of designing a garage and am planning on using 1×10 western red cedar vertical rabbeted siding. I’m going after the “barn look”. I’m having difficulty thinking of the best way to flash the window and door casings. The only way I can of is to route a groove about 1/4″ wide and about 3/8″ deep above the top of the casing, insert the flashing, tack it down, and caulk the groove. Any better methods out there?
  1. JimT. | Jun 04, 2001 06:19am | #1
    Hello All,
    I'm in the process of designing a garage and am planning on using 1x10 western red cedar vertical rabbeted siding. I'm going after the "barn look". I'm having difficulty thinking of the best way to flash the window and door casings. The only way I can of is to route a groove about 1/4" wide and about 3/8" deep above the top of the casing, insert the flashing, tack it down, and caulk the groove. Any better methods out there?
