flat roof pitch
AP | Posted in Construction Techniques on October 6, 2003 12:41pm
I’m currently building a flat roof extension on the back of my house. The roof line needs to have a minimum 2 degree pitch.
What is the best way to work this out?
ap.
    BossHog | Oct 06, 2003 05:59pm | #1
    Isn't "flat roof pitch" a contradiction in terms?
    Kinda like "military intelligence"?
    Military justice is to justice what military music is to music.
    1. UncleDunc | Oct 07, 2003 07:11am | #8
      Flat and level are two different things.
        BossHog | Oct 07, 2003 02:29pm | #10
        "Flat and level are two different things."
        Gosh darn it, I was kiddin' around.
        But flat and level sound purty close to me................(-:My wife keeps complaining I never listen to her...or something like that.
        1. Piffin | Oct 08, 2003 04:39am | #11
          Not to roofers who don't use such specific terms
          Well, maybe - flat is any roof less than 2/12 pitch but level is an unattainable quality because even if you built it perfectly level, snow would make it settle iun the middle and dish out to pond water, which will get deeper every year from the weight.
      2. Catskinner | Oct 09, 2003 01:32am | #12
        All-righty, then -- so THAT explains the problem I was having with my former concrete subs!
        DRC
  2. csnow | Oct 06, 2003 06:46pm | #2
    I get 0.41904923390097276/12  pitch.
    Meaning 0.41904923390097276 inches rise for every 12 inches of run makes a 2 degree angle.  (hope I did it right)
    Many calculators on the web to help you avoid doing the trig.
    Try this one:
    http://www.1728.com/trig.htm
    Also, for standard pitches, this site has angles listed:
    http://www.roofingpeople.com/Index.cfm?Page=PitchDeg
    Best of luck
    1. AP | Oct 07, 2003 02:32am | #3
      I knew there would have been some basic formula for this. Thanks for pointing me in the right direction.
      ap.
      GoldenWreckedAngle | Oct 07, 2003 03:44am | #4
      I checked it in Autocad and you're dead on.Kevin Halliburton
      "I believe that architecture is a pragmatic art. To become art it must be built on a foundation of necessity."  - I.M. Pei -
      1. csnow | Oct 07, 2003 06:01am | #5
        Just had too dust off the part of my brain that stores high school math...
        My geometry teacher would smile big if he knew.
        Not exactly CAD, but it works sometimes.
        CapnMac | Oct 07, 2003 06:35am | #6
        DId that myself, too.  But my pitch triangle routine reported it as 7/16 in 12.  I had to do the math to get 0.4 in 12.
          GoldenWreckedAngle | Oct 07, 2003 07:09am | #7
          Type "units" and set your Autocad units to "Engineering" instead of "architecture" to get decimals.Kevin Halliburton
  3. Framer | Oct 07, 2003 02:02pm | #9
    If you are given the 2° for the pitch to figure it out on your own with a Scientific Calculator or Construction Master Calculator you can just multiply the Tangent of the Degree by 12.
    Using a Construction Master Trig or a Scientific Calculator.
    Tangent of 2° * 12 = .419049 or 7/16"
    The pitch is 7/16:12.
    For every foot of run your rise will be 7/16".
    Construction Master Calculator.
    Press [2] [Pitch] Twice, Returns -  27/64
    Press [Conv] [1] Returns -  7/16"
    Press [Inches] Twice, Returns - .419049
    I have alot of books with answers but I just like to figure out how they got them.
    Joe Carola
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
