flat roof question
troys | Posted in General Discussion on March 19, 2009 08:21am
Hello everybody I am going to have to replace the roof on my house the roof is a parapet style roof with a slight slope and it currently has a torch down roof with 3 inch’s of foam insulation underneath. I am looking at roofing materials/systems and trying to decide between a traditional built up roof with a mineral service, I don’t want tar and gravel because of the need o walk on the roof to clean leaves from a large oak tree. The other material I am considering is a PVC material like “Dura-Last” Any opinions would be appreciated. I live in the San Francisco Bay area
Troy
  1. seeyou | Mar 19, 2009 09:24pm | #1
    My preference for a situation such as yours would be EPDM or TPO/PVC.
    http://www.quittintime.com/      View Image
    McDesign | Mar 19, 2009 11:57pm | #2
    Seal-O-Flex!  Just basic tools; no fire.
    http://www.sealoflex.com/roofs
    Forrest - have done some of that
  3. Piffin | Mar 20, 2009 02:41am | #3
    I'm an EPDM fan, but don't know the new generation of PVC roofings
  4. Catskinner | Mar 21, 2009 08:54am | #4
    Look around and see if anyone in your area is applying TPO (thermoplastic olefin). It's like a swimming pool liner that is UV resistant, no need for a tear-ff of the previous roof because it's very light weight.
    I've done a lot of roofing and I paid someone else to put this on my house.
    Best money I ever spent on this place.
    1. troys | Mar 22, 2009 01:57am | #5
      Thanks so much for your and everybody elses response.Troy
  5. ponytl | Mar 22, 2009 02:01am | #6
    just curious... how old is the torchdown?  and why does it need replace'n?
    i have several torchdown roofs that are over 10 years old and still look like new...
    just curious
    p
    1. eas | Mar 23, 2009 02:09am | #7
      You don't say anything about color. A white or silver roof is a good way to reduce heat load in the summer if your roof gets a lot of sun (but, given that you are in San Francisco might not be an issue.)
      1. troys | Mar 24, 2009 09:47am | #9
        Currently the color of the torch down material is a dark brown. When I replace it I was thinking about a light color or a white PVC you can't see the roof from the street so the color is not an issue from an aesthetic point.ThanksTroy
    2. troys | Mar 24, 2009 09:44am | #8
      I have a leak I found where I think it is leaking and did a repair so I will see how it lasts, I was looking at my records and it looks like the roof is about 12 years old. Of course with the drought in California it might not be an issue.Thanks
      1. Piffin | Mar 24, 2009 02:10pm | #10
        torch down modified ages in UV pretty fast after ten years. My procedure has always been to paint a coating on it every five years. Doing that and in climates with lower UV exposure, I have not had one wer out that I know of, but modbit is somewhat uncertain as to aging in various situations. In general, I think of it as a 10-15 year roof.for instance if the applicators use too high a temperature it will change the chemical composition of the asphalt and make it more brittle - shortening the lifespan.The brown colour suggests both aging and pollution exposure. If you get down and see microfissures in the surface also, or the ooze at seams seems brittle, it is definitely time to replace.
        1. troys | Mar 26, 2009 05:56am | #11
          By brown color I ment the actual color of the material. I do think it is at the end of its useful life though and we do get a lot of soot from trucks and the roofing material on the top of the parapet is starting to crack.Thanks
          1. eleeski | Mar 26, 2009 08:42am | #12
            How about an elastomeric roof? Metacrylic is in San Jose. Their elastomeric system is fairly easy and reasonably durable. Plus it is very easy to repair and maintain (repaint) on a flat roof.
            Eric
          2. troys | Mar 27, 2009 11:41pm | #13
            Had not heard of that type of material. I will look into it.Thanks
