I have done a lot of porch railings here in Ohio. But they are always done between two walls or columns. I usually use treated 4X4’s and wrap them with cedar and attach my handrails to these. On this particular job , I have a flat roof that is 20′ X 20′. The railing will be on 3 sides of the roof. I need a way to secure the posts to the roof other than using Simpson post bases. Any suggestions would be appreciated. Thanks Bill C.
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
That gets tricky if the underlying framing hasn't been preplanned and prepared for it and if there is no deck being built to protect the roof.
What kind of roofing material is on it and how old?
It is probably at least 30 years old tar roof . The roofer is planning to put down a mop installed Ribberoid roof pver the existing as it does not leak or have any flat spots where water settles after rain. Thanks
In that case, you can open it up to place framing to attach to, patch the spots, then seat metal brackets such as Simpsons or custom wider flange ones, then have the roofer install pitch pans around the posts, then trim over with cedar.OrYou could look into the type of hardware Fypon uses that makes up a torsion box, seat that flange in tar and lag it down, then have him roof over the hardware, then mount the posts on the all thread.There are other options, but there is no truly good way to mount posts on a roof and expect as much strength as on a deck and as waterproof as an unpenetrated roof
if you can do a welded metal rail system... then you can weld it into one piece...with flat metal pads on the corners an mid posts set onto pads of torchdown and attach it at the 2 walls you have... with a 1.5" pipe top & bottom rail... it isn't going anywhere...
p
Good thought - no penetrations in the roof membrane
Hello Bill, when you say the railing runs around three sided of the roof are you then saying it terminates at two points into a second story exterior wall? If that is the case I have a post I first wrote here back in 2002 that might address your situation. I repost it again here with some minor editing
Hope that helps and give you another opinon on how to approach roof deck railings.
Thanks I did notice the original posts had a metal "foot" around them about an inch tall and they look like they were fastened to the roof and then tarred over. I know the house is 90 years old but I am sure the railing is less than 30 years old. Thanks., bill c.
I think Scott McBride did a nice article in FHB on one he built. Quite a while back. I'll let someone who's got the disk find it for you.
That said, here's another vote for monolithic steel, whether you box it out with wood or not.
I don't like roof penetrations.
AitchKay
you know i like steel...
i did a deck 3ft above a flat roof where i fastened 3" round steel posts to the framing below the roof where i came through the roof i used standard flashing boots (metal & rubber) like you would use for any vent pipe come'n through the roof... they allow the pipes to move a bit and still keep everything sealed...
since i welded flanges on the pipe for mounting to the frame work... and holding the deck support joists... and flanges for the deck rail... i had to slide the boots on the post during fabrication... then slid them down to the roof for sealing... has worked well for about 4 years... ( i might have been able to streach the rubber over the lower flange after but wasn't worth the risk of tear'n em)
p
