Flexible bullnose corner installation
IMSA | Posted in Construction Techniques on December 21, 2006 12:08pm
OK,
I can usually figure out just about anything but I having some real questions about the bullnose corners in my project.  I have an office area off the upstairs bedroom with a 7′ barrel ceiling. The barrel ceiling opens into the bedroom which again is a barrel ceiling about 12’ tall.  The bedroom ceiling is at about 65 degrees where the office ceiling meets so not only do I have an arch for the office barrel ceiling but the bedroom ceiling is at an angle as well.  Needless to say I’m having a little problem bending the bullnose material to fit.  My questions are as follows. <!—-><!—-><!—->
Do I install the bullnose in perhaps 1’ pieces so it will be easier to manipulate?<!—-><!—->
Do I fill the inside of the bullnose material with mud before I install to fill the void between the drywall and bullnose?<!—-> <!—->
Are the many small holes in the bullnose strip for screws or is it installed with just mud?<!—-><!—->
The bullnose material appears to be some type of plastic.  PVC maybe.  Any advice is greatly appreciated. <!—-><!—->
IMSA <!—-><!—->
Edited 12/21/2006 4:15 am ET by IMSA
  1. calvin | Dec 21, 2006 02:28pm | #1
    U.S. Patent # 6,119,420
    There is arch bullnose.  Notice the cuts on one side of the bead.  This allows it to bend easily.
    Try Trim-Tex or one of it's distributors.
    http://www.trimtexinc.com/
    http://www.quittintime.com/
    basswood | Dec 21, 2006 04:27pm | #2
    I avoid using fasteners, they tend to pinch the bead in, preventing a continuously smooth curve. The bead can be glued on with construction adhesive and held in place with a few staples until the glue sets up.
    On adhesives, some like using sprays (3M has a hi-tack 76), but PL is fine. I use PowerGrab by Loctite, as it is white and cleans up with water. PL-300 has nice grabing characteristics too. Smooth out the glue and mud over it after it sets.
    1' pieces would make the curve into a polygon...the joints would show.
    Edit to add: the 3M spray adhesive may have limited repositioning, other options may be more forgiving.
    Edited 12/21/2006 9:28 am ET by basswood
    1. IMSA | Dec 27, 2006 12:06am | #3
      I would have posted back sooner but I was mudding and taping.  The Power Grab worked great for the flexible bullnose.  I also appreciate the advice about the better the mud job the less sanding.  I really don’t care to drywall because it takes me 3 times as long to do a job than a professional but I always do it anyway.  In the past I took less care applying the mud and figured I would just sand it down. This time I took my time with the mud and have had to do considerably less sanding. Again, thanks to everyone.
      IMSA
      1. IMSA | Dec 27, 2006 12:12am | #4
        By the way, if this helps anyone who’s considering installing skylights, I installed 4 Velux skylights and couldn’t be more pleased with the results. I dreaded having to install skylights after hearing years of horror stories about leaks but I’ve had zero problems. I set aside an entire weekend to install 4 skylights and to my amazement I was done in about 4 hours. No leaks after days of heavy rain. I highly recommend Velux..
        IMSA
Picture-Perfect Pergola
