flexible duct for stove exhaust fan?
DoRight | Posted in Construction Techniques on September 10, 2016 06:12am
I have a very odd and convoluted path for running an exhaust fan for a kitchen.  I love solid vent pipe and would love to figure at way to use it but …. man …. not sure I can .  Can I use some flexible duct?  Is there any issues to be aware of??
My configuration, if I can explain, is:
Stove on 45 degree interior wall.  So I can go up with retangular duct.  If I use a rectangular elbow teh vent will now be directed at a 45 degree angle to the floor joists inwhich I need to run the vent horizontally.
From that elbow I suppose I could convert to a round vent and use a 45 degree adjustable (elbow?).  Then run horizontally toward teh exterior.
However, I have a can vent in the bay with 4 inches of clearance above it, so a 6 inch round duct is no good.
Ok, say I get to the outside wall.  At that point I can come out into my roof overhang.  And I mean IN it ( have 2 x 12 rafter tails and the vent from inside the house would be more or less inside the rafter tails.  AND I have an intersecting roof coming into the roof overhang in which teh vent dumps.  So I need to do one more 90 degree turn within the rafter bay and perhaps dive it down a bit to some kind of a termination.
So if I could use flexible ducts it would seem to be easy enough to run verticlely from the hood , convert to round ducts attaching flexible ducts and snake that all the way to the outside.
Am I missing anything?
What type of flexible duct would be best for this application if at all.
Thank you all.
  1. florida | Sep 15, 2016 03:06pm | #1
    Lots of companies  make flexible SS flue liners which would work just fine.
  2. jimmiem | Sep 16, 2016 07:59am | #2
    Any duct size/run length specs from the fan manufacturer?  Inspectors and fire departments get concerned about grease fires in kitchen exhaust ducts.
    1. DanH | Sep 16, 2016 08:42am | #3
      Yeah, any flexible duct that's used must be certified for use as range hood duct, since the buildup of grease in the duct is a significant concern.
Choosing a Paintbrush
  • The New Old Colonial
