Floating trusses
CharlieS | Posted in Construction Techniques on February 7, 2005 02:46am
Here’s the situation
1. 30 year old apartment building
2. Second floor apartment
3. Floating trusses
4. 1st. time this is occurring in this area (center) of   building. Has occurred on the east end of the apartment building several years ago.
5. Solution in the past, install crown molding to ceiling only and let it float up and down the wall.
6. Was a real pain finding something solid to nail to the last time.
7. I was thinking of installing something flat that has a profile on the outer edge against the ceiling first, then nailing the crown to that. Call it a built up or 2 piece trim.
8. Has anyone ever tried this idea and if so what did you use. I don’t want to get carried away with trim and over power these rooms since the ceilings are 8ft. and the rooms are 10X12.
9. The existing trim in the room is stained Hollywood style. The Crown molding will be your standard run of the mill style and painted.
Thanks, charlie
    SamT | Feb 07, 2005 02:57am | #1
    OOOooowww!!
    My Eyes. My Eyes.
      IMERC | Feb 07, 2005 04:44am | #3
      must be a new poster...
      just a guess..
      proud member of the FOR/FOS club...
      WOW!!!   What a Ride!
  2. Piffin | Feb 07, 2005 03:09am | #2
    Sounds good to me. Use a little PL putting up the first piece, maybe rip a back bevel nailer to place behind the finish ones, and stick it all up with cross hatched nails from the pneumatic.
    So - you like small crown and large print, eh? You must not be a lawyer. They like small print and large crowns
      IMERC | Feb 07, 2005 04:45am | #4
      ROAR!!!!!
      WOW!!!   What a Ride!
    IMERC | Feb 07, 2005 04:47am | #5
    BASE MOLDING...
    WOW!!!   What a Ride!
  4. Fuzzy44 | Feb 07, 2005 08:43am | #6
    I can read your post from 20 feet across the room
    1. UncleDunc | Feb 07, 2005 09:23am | #7
      >> I can read your post from 20 feet across the roomYou say that like it's a bad thing.
Outdoor Lighting
