Floor finishing question
evetss | Posted in Construction Techniques on January 28, 2004 07:15am
Going to be finishing some wood stairs.  Would you finish the stairs differently from the stringers. The stringers will be lacquered or varnished.  Wouldn’t the stairs be finished with something like urethane?  Or would varnish be just as durable?
    Sphere | Jan 29, 2004 01:28am | #1
    Make that a polyurethane..floor finish for the treads, and what ever ya like for the rest.
    Go Stab yourself Ya Putz! Ya think I Parked here?
    1. evetss | Jan 29, 2004 05:46pm | #2
      Thanks...finish the treads first and then the stringers? Would you recommend spraying the polyurethane?
        Sphere | Jan 30, 2004 12:04am | #3
        It really does not matter what order you finish the treads or stringers..treads tho' I would start at the top and work down so ya don't get stuck upstairs..or another way is do every other one and let dry, then come back and finish the rest.BtDT. Spray poly? I useually don't..too messy inside..brush thee thin (no sag) coats..and yer all set.
