Floor Framing for Large Format Tiles
borlebros | Posted in Construction Techniques on April 25, 2023 04:00pm
I recently scored an unreal deal on some large format tile at a liquidation auction. I will use it for a  build this summer where it will be replacing the originally spec’d vinyl plank flooring.
But when I say large format I really mean LARGE FORMAT. Its 24″ X 48″ porcelain tile! The now defunct business sold to clients building commercial or institutional buildings, not typically residential.
I think I have a reasonable expectation of the increased difficulty of installing LFT, so I definitely don’t want to make things even harder by having a subpar floor assembly on which to install it on.
At the moment the plans spec 14″ I-Joists, 16″ O.C. for an 18’6″ Span, with a 23/32 subfloor.
I’m wondering what I should do to beef up this structure to minimize deflection. Off the top of my head I’d say doubling up or decreasing the spacing of the I-Joist at areas with increased dead- and live-loads such as the kitchen table and peninsula. Using screws with reduced spacing between the fasteners and glue for the subfloor, and adding a  layer of APA Group 1 or CANPLY 0121 exterior-grade plywood underlayment, offset from the subfloor. Again glued and screwed with reduced spacing but not fastened through to the I-Joists, to allow some isolation between the underlayment and the framing.
Finally, I would likely use a decoupling membrane and a thin set designed for LFT installations.
I’ve never seen the Advantech Floor panel used in my area (Alberta, Canada) but I wonder about sourcing that for this project.
LFT installation in a residential setting hasn’t caught on yet here so I am hoping someone else has experience with this and can provide some guidance.
Thanks in advance to the great community!
  1. mgmahan | Apr 25, 2023 06:05pm | #1
    I wouldn't worry too much about the diaphragm if you beef up the joists. I'd probably use 1 1/8" plywood but any two layers should do. Your floor has to be dead flat. I'd use a full mud float to insure this. Any unflatness will be terrible with such a large format tile.
    1. borlebros | Apr 27, 2023 12:54pm | #3
      How thick would you with the float?
    ct_yankee | Apr 25, 2023 07:31pm | #2
    I would double up on the floor sheathing. I agree with mgmahan that flat is essential, but with that size tile a small amount of subfloor deflection could result in a crack. Mud for flat, stiffer subfloor to combat deflection.
Picture-Perfect Pergola
