What is the best (read under $200) software program for drawing a simple floor plan? I don’t need 3-D 0r sofa templates
Do any of them allow you to spec how long a wall is and draw it for you, instead of creeping the mouse along or nudge as one program put it.
You can't get anywhere near the best for under two bills...
All I have seen let you edit a wall length or position with an edit feature.
It has been years since I looked at anything other than the Soptplan I use, but I would look at Floorplan ( used to be able to get it free) or Turbocad
Sketchup is also free and highly spoken of for some kinds of design.
http://sketchup.google.com
try it, you'll like it.
su....
or pencil, paper, and drawing board.....
the second is usually the best choice unless you intend to keep on doing design work
no learning curve.....just draw
IF you intend to keep on doing housing design work... then you should get into 3-D cadMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
