Looking to see if my floor sheathing layout is correct, I only have about a 10″ strip along the south edge and don’t know if that is too narrow or does that need to be longer. I have not been able to find anything that says there is a minimum width from edge of rim. Thanks.
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
