Floor surface for screen porch
ElegantSolution | Posted in General Discussion on April 17, 2008 05:59am
Does anyone have a good idea for an alternative flooring choice for a screen porch. Currently, I have carpet over 3/4 inch treated plywood over 2×10 treated joists 16 in. o.c. and spanning 11 feet. I am considering tile, but wonder if the framing can support it. What else can I use? Any sheet goods like vinyl?
  1. peteshlagor | Apr 17, 2008 06:03pm | #1
    Stamped or stained concrete!
    Or more accurately, thin, flexible, lightweight concrete.  Like this:
    http://forums.taunton.com/tp-breaktime/messages?msg=91581.1
  2. Hudson Valley Carpenter | Apr 17, 2008 09:34pm | #2
    That floor is plenty strong enough for tile...with the usual thinset/backerboard, thinset/tile application.
    You could use sheet vinyl or vinyl tiles of course, directly on the 3/4 ply.  Peel and stick vinyl tiles are very quick and easy to install.  Also very inexpensive.
      Dinosaur | Apr 18, 2008 02:46am | #3
      BLEEEEEAAAAAAHHHHH!
      Yer kiddin', right?
      Dinosaur
      1. Hudson Valley Carpenter | Apr 18, 2008 05:13am | #7
        Yer kiddin', right?
        He asked about vinyl so I was trying to cover all the possibilities.  It's not like he can't look at the stuff and decide for himself if it suits his needs.
          Dinosaur | Apr 19, 2008 03:10am | #8
          Sorry, Hud. I meant to write 'He's kidding, right?' as a joke in response to the OP's screen name, 'Elegant Solution' and the obvious lack of elegance in that particular solution....
          Dunno what my fingers were thinkin'. Gimme a dope slap and call it even?
          Dinosaur
          1. fingersandtoes | Apr 19, 2008 06:20am | #9
             A lot of the cabins at Mt. Washington, that get used both summer and winter, have what looks to me like Flexco rubber flooring in their entry porches. I quite like the look.
            Dinosaur | Apr 20, 2008 12:47am | #11
            I'm not familiar with the brand-name Flexco, but I have seen some very robust industrial rubber flooring used on exterior decks at ski centres. If it can stand that kind of traffic, it should be able to stand just about anything.
            But whatever the final flooring is, if that porch is exposed to the weather the flooring will have to do one of two things: either allow good drainage so no rot or frost-heave develops under the finish floor, or, if there's finished living space under it, the whole floor assembly must be built like a flat roof: completely waterproof so that no water can get into or through it.
            Dinosaur
          3. Hudson Valley Carpenter | Apr 19, 2008 07:36am | #10
            No problem.   In my opinion you were well within your rights to question that suggestion of mine, given that this is a message board which is aimed at better quality products and methods.
            I was motivated by a memory of my first attempt at laying a kitchen floor with peel and stick squares, many years ago.
            Using that material wasn't my idea but I was able to achieve an impressive enough result in a couple of hours, start to finish.
            It was a nice confidence builder for me, as a novice at laying out a floor and cutting it in.  I just followed the instruction sheet that was in the box of vinyl tiles...when my employer wasn't in the room.  ;-)
            Anyway, it's one possible way for any home owner to start, something that can be done in an afternoon with a few simple hand tools, and should serve OK in the situation described.
            If and when he decides to replace it with something nicer, the peel and stick tiles can be removed without much effort.
            Edited 4/19/2008 12:46 am by Hudson Valley Carpenter
    Dinosaur | Apr 18, 2008 03:00am | #4
    Run your floor framing specs through the JohnBridge span calculator and it will tell you if and what kind of tile you can use over that framing. Typically, your subfloor will have to be bumped up to 1¼" thick, but if you have standard ¾" ply in place already, that only means adding a layer of ½".
    However: The real problem you might have is not strength, it is weather exposure. You say this is a screened porch, from which I infer that the floor is subject to wind-blown rain and snow. That means your tile job has to be absolutely bombproof, or water will infiltrate it, freeze, expand, and crack your tile job all to hell.
    To do it right, you would need the following: 1¼" plywood subfloor over adequate joisting; 'Blueskin' or similar roofing membrane adhered to the subfloor; ½" 'Durock' or similar CBU laid over thinset (for void filling; nothing sticks to the top side of the Blueskin) and screwed on 8" centers through the Blueskin into the subfloor; Ditra tile membrane over the CBU; and finally your tile, grout, and sealer.
    Dinosaur
    foolish men call Justice....
  4. Marson | Apr 18, 2008 03:18am | #5
    How about fir flooring? That is the traditional porch floor.
  5. renosteinke | Apr 18, 2008 03:55am | #6
    Personally, I think you're going in the wrong direction.
    As I understand the term, a 'screened porch' is always open to the weather. Even with a roof and some overhang, there's still plenty of opportunity for rain to come in through the screen, plus the slop carried in by your feet. The floor is also usually exposed to quite a bit of sunlight.
    I had to face these concerns when I made some window boxes for my cats. In the end, I laid some carpet atop wire shelving; the open underside aids greatly in drying the carpet after a rain.
    I'd want to do something similar .... If I couldn't lay the carpet -just lay it, don't glue it - atop expanded metal grating, I'd use a saw to cut lots of slots in the plywood.
