I’m planning on replacing my existing vinyl kitchen floor with ceramic tile. After pulling up the old floor, how do I remove the old glue residue. Or do I just need to knock down the high spots prior to laying the thin set.
![](https://images.finehomebuilding.com/app/uploads/2024/08/15131650/FHB-645-Pod-Feature-thumb-16x9.jpg)
Listeners write in about condensing dryers, giant gears, and saggy doors and ask questions about chimney safety, black windows, and rot-resistant assemblies.
A few products are made to remove flooring adhesive, that combined with a floor scraper and some time,you'll have it licked. Make sure the adhesive is all off for good contact adhesion with the tile and mortar/thinset. By the way what type of underlayment are you working with? Plywood? OSB? Concrete?
*And see this threadRich Beckman
*Norm, What is the underlayment that you are putting the tile over. Is it a concrete slab or perhaps a raised foundation(plywood/OSB). Need more info... If it is wood you could place hardibacker right over the existing floor.Depending on the condition of the underlayment. If it is concrete then thats another story.
*I rented a floor sander to remove the old adhesive, worked pretty good, had the sander back to the rental house in an hour.
*The underlayment is concrete with a multi-color (patchy light gray to a brown) floor leveler compound. The vinyl floor has been in place for over twelve years. I have pulled up only a small area of the floor, so I don't know what I will run into when the rest of the old stuff comes up. The floor will be replaced as part of new kitchen cabinet installation project.
I'm planning on replacing my existing vinyl kitchen floor with ceramic tile. After pulling up the old floor, how do I remove the old glue residue. Or do I just need to knock down the high spots prior to laying the thin set.
