Fluted Casings
| Posted in General Discussion on January 5, 2000 07:12am
I would like to get some opinions and facts about fluted casings.
What is the most popular style? Stopped flutes or continuous flutes.
Also I would like to know the thickness that is most commonly used. 1/2″, 5/8″, 3/4″, thicker?
I seen some prefab casing at HD and it appeared to be 5/8″ or so.
If it matters the casing will probably have rosettes at the corners.
The reason I ask all this is because when I have my house built I am going to do alot of the trim carpentry. Will probably even mill the casings myself as well as the rosettes.
I understand that to get a nice looking stopped flute then I will probably have to buy a molding head cutter for the TS. Have tried with the router and the ends just didn’t look quite right being rounded. I like the tapered look that you get from a molding head. If possible could a jig be used with the router that would sweep the bit(and router) up out of the work to give the same effect?
Thanks for any thoughts on this.
glenn
  1. Guest_ | Jan 05, 2000 06:13pm | #1
    Glenn,
    Yes, you can make a jig to accomplish the tapers you desire. It is basically a ramp-up at the ends of the jig that steer your router down the piece of stock. If you don't care for the finished look you can always finish the tapers off with a chisel or gouge.
    Eric
    1. Guest_ | Jan 05, 2000 06:20pm | #2
      *Hi Glenn, The thickness of the casing is usually set up by the manufacturer so that the corner blocks and plinth blocks will be thicker and overhang the casing giving it a reveal. Last year I made up all the casing, corner blocks with rosettes and plinth blocks for a 4800 sq ft home. A moulding head for a table saw does do the best job as it tapers the flute at the end. You can achieve this same taper with a router and a sloped jig placed where you want the flutes to stop; however I feel that if you are making alot of casing it is better to use the table saw and moulding head. I made my casing out of 3/4" yellow pine, and the plinth and corner blocks out of 1-1/2" yellow pine. For the corner blocks I used a drill press set up for about 620 RPM with a carbide rosette cutter. I found that it worked best to cut a long length of stock to the width of the block and do a careful layout where the rosettes should be milled. After milling the rosettes you then can cut out the individual blocks. I milled a roman ogee edge on the ones I made. There is a picture of a door under a stair case that I made the trim for which has the rosettes and some beaded casing. Go to http://business.fortunecity.com/ingram/109 and look on page 4. Mad Dog M.
      1. Guest_ | Jan 05, 2000 07:12pm | #3
        *Thanks for the suggestions, I was also wondering how you would handle an arched top door or window casing. Do the tops usually have flutes as well or just plain? thanksglenn
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
