foam insulation above wood deck
bobalu | Posted in General Discussion on May 8, 2006 06:18am
We are re-modeling a small cottage in NJ and want to retain the appearance of the open beam and wood ceiling.  We are considering 2″foam above the wood deck and then ply sheathing on top, covered with asphalt shingle.
My concern is preventing roof rot on the lower roof deck.  Is there a way to prevent condensation using this system?
Bobalu
  1. Danno | May 08, 2006 10:46am | #1
    I would think putting a vapor barrier on the lower deck under the insulation would work. (At least in a climate where heating is your main concern--if you are using refrigeration ("air conditioning"), you may have condensation in the summer.)
    1. bobalu | May 08, 2006 03:13pm | #2
      Thanks for the come-back Danno.
      Bobalu
      1. Danno | May 08, 2006 03:38pm | #3
        You're welcome. You might check out a web site called "buildingsciences.com"--it tells a lot about insulation and vapor barriers for various climates. In NJ, you may not want a VB on either side of the insulation--let the vapor flow freely in and out. The problem I see is that depending on which foam insulation you use, it itself can be a vapor barrier. I think Dow Styrofoam is. I'm not sure about dense fiberglass panels.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
