Foam insulation in Michigan
user-3064971 | Posted in Energy, Heating & Insulation on December 4, 2013 04:12am
Hi All
I’d like to know if anyone has recently used closed cell foam to insulate your house in Michigan?
1   What was your experience (did it perform as expected)?
2 What type of wall construction did you have (2×6, flash and batt, etc.)?
3 What are the code requirments for insulating a new home in Michigan?
  1. kxm1 | Feb 02, 2014 01:28pm | #1
    hi user...
    ...i have not done any of that insulation in MI but i will tell you that if installed correctly it will perform at least as well as it is expected to.
    you can find info on the code online or at your local codes office,
    good luck!
  2. F_Timmons | Jun 25, 2014 03:08pm | #2
    That kind of insulation has a high R-value and will increase your insulation and temp. levels signifigantly. I have not used it in Michigan but I do know it works. If you want more info I know univfoam.com has a variety of insulation options and maybe that will help you out? I agree that you can find the codes online, it just might take some research.
    -Frank
