Foam insulation question
Royalt | Posted in Energy, Heating & Insulation on September 17, 2007 01:10am
Greeetings from NY I have been looking into that “Tiger Foam” to sprey on a box in a basement . Is that product any good or is there another one that would work better
 BTW I got some advise here a year ago about insulating an apt . I used rR-21 walls and 38 in the cieling (2 Layers of 19 ) I used 1″ foam rigid and furred them out before drywall . it was the best thing I ever did . The gas bill is great
 Thanks again for the advise
 Thanks in advance
Roy
  1. rez | Sep 17, 2007 08:43pm | #1
    Greetings Royalt,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    sobriety is the root cause of dementia.
    1. Royalt | Sep 18, 2007 12:40am | #2
      Roy
      1. rez | Sep 18, 2007 12:54am | #3
        Sure.
        What is the box in the basement for and what size is it?
        1. Royalt | Sep 18, 2007 01:06pm | #4
          Rez its the rim joist going around the outside of the floor joist 2x10
          Regards
          Roy
          1. rez | Sep 18, 2007 01:49pm | #6
            So what you are wanting to do is insulate the perimeter of the above ground area of the basement walls?
          2. Royalt | Sep 19, 2007 04:12am | #13
            You got it cuz  i was wonderin if any of you ever heard of that product called "Tiger Foam "  and if you heard if it was any good or nor por if you could reccomend one . i was always under the impression that FG was best to use but the airspace kills any benefit that the GF gains I dont know if a foam installer would want to bother with a small job like that
            Regards
            Roy
          3. rez | Sep 19, 2007 02:03pm | #16
            The description of 'box' used in the first post kind of thru me off understanding what you were wanting to insulate. I take it now that you are speaking of the areas between the floor joists of the first floor sitting on the sill abutting the rim.
            Spray foam would work well there in that sealing any possibility of air infiltration being more important in this common troublespot than the subject of R-values.
            In the archive listing of old threads on Breaktime there are a number of threads mentioning Tiger Foam that may be informative.
            If you scroll up in the upper left corner of your screen there is an advanced search function
            Post New
            Advanced Search
            that upon clicking will take you to a page of instructions directing you to previous threads dealing with whatever you type in the search bar which is found on that page.
            If you type in 'tiger foam',  'rim joist insulation' or other keywords of a subject matter you'll get a supply of data from those old threads.
            As you'll read some advocate a light coat of sprayfoam followed by pieces of cut foamboard depending on the ease of accessibility and depending on the size of the basement some a smaller aerosol spray as GreatStuff coupled with foamboard for the DIY.
            Pleasant reading to you.
          4. DanH | Sep 19, 2007 02:14pm | #17
            SOP here now is to inset the rim joist about 1.5" and then apply that much rigid foam on the outside to fill the resulting notch.
        2. mike_maines | Sep 18, 2007 01:09pm | #5
          Do you know how to make a lightbulb symbol?  I feel like I need it.
          1. rez | Sep 18, 2007 01:54pm | #7
            Couldn't find one.
            Time to call in the gunner.
          2. rez | Sep 18, 2007 01:55pm | #8
            bump
            Edited 9/18/2007 6:55 am ET by rez
          3. DanH | Sep 18, 2007 02:15pm | #9
            I went to college for five years to learn that. Can't just tell you -- wouldn't be fair.
          4. mike_maines | Sep 19, 2007 01:37am | #10
            I'm going Fortan on your a**!
          5. DanH | Sep 19, 2007 02:10am | #11
            Not even close.
          6. mike_maines | Sep 19, 2007 03:08am | #12
            School me.
          7. DanH | Sep 19, 2007 05:37am | #14
            Like I said, ya gotta go to school for five years and learn the secret handshake.
          8. mike_maines | Sep 19, 2007 01:08pm | #15
            I went for four
            They must have taught that the fifth year.
          9. rez | Sep 19, 2007 03:04pm | #18
            Is that a lightbulb or an old lady bending over?
