Foamular (XPS) and Fire Blocking Corners of Basement Walls
Hello,
I have seen numerous examples where basement wall are first insulated using Faomular (XPS) and then framed.
Hello,
The DeWalt 4.5 in. — 5 in. grinder has variable speed control (six speed settings), a safety system that shuts down the tool if the blade binds, and a brake that stops the wheel after the trigger is released.
Depends on the XPS
In some cases, XPS may not require thermal or ignition barriers (it is important to consult the ICC-Evaluation Service report for a specific product to see if that product is exempt from requiring such barriers).
Please see each manufacturer’s current evaluation reports which can be found at http://www.icc-es.org.
