Foilface iso board on inside of SIP wall
Calling all vapor barrier experts!
I have a question about the suitability of putting a 1 inch layer of Thermax/Tuff-R/whatever manufacturer calls it, on the interior face of the SIP walls of the house I’m slowly completing.
I need to space the drywall inward to accomodate wiring that will be on the inside face of the SIP wall, so I figured I’d upgrade the R value with the spacer and kill two birds with one stone, adding a radiant layer and a vapor barrier. Cost of heating went way up since I started this project, so this upgrade seemed like a good idea.
Can anyone out there imagine any possible negative consequences to this setup? I know there’s debate about vapor barriers but this seems harmless. Would unfaced insulation make more sense?
Any help would be greatly appreciated.
Thanks,
Nick
Greetings i,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
94969.19
In the beginning there was Breaktime...
94969.1 Photo Gallery Table of Contents
Let's run this thru one more time.
bump
