I’ve got a client who wants a swing-down (or up) laundry folding table. It will be a 24″ deep by 36″ wide plastic laminate on particle board countertop with a piano hinge to secure it to the wall.
I’m trying to avoid using legs when the table is in use. Can anyone recommend any sturdy hardware that will lock the table in the open position yet be easy for an 85 year old lady to close?
I don't know of a good hardware source, but have the following suggestions.
If the table folds up instead of down, you can make braces pinned to each end of the table that slide up and down which form a 45° brace when the table is down.
Be careful on the height. It may need to be shorter for her use and stowage than you might be inclined to mount it for you. Particle board is quite heavy, and it sags, besides. I'd recommend birch plywood. In my opinion the extra few bucks would be worth the weight savings for this particular client. The latching mechanism needs to be so safe that arthritic hands can't lose control and drop the table. Maybe rounded corners, too.
My 1950's era sewing table has a 1/2" square metal arm that swings out under the wood to support it when unfolded. It seems pretty sturdy to me and has similar dimensions to the folding table you are building, although in my case the support is from the short end and it extends out long. When done it slides back into a slot in the table base. If they don't still make such hardware, then you could probably cannibalize a couple of old sewing tables for it.
Häfele have three different models, cat. no's. 568.65.700, 568.65.100, 568.66.700, or 568.60.710. In US tel 800-423-3531. Slainte.
I would be concerned about the weight of the table. A 24x36 piece of particule board maybe kind of heavy for an 85 year old woman. Cut a piece an see if she can lift it.
There are several special locking hinges and props available, but they tend to be fairly hard to operate.
You can make your own, easier-operating unit, using three hinges and two pieces of wood. (There are two or three basic configurations.) The trick is getting the geometry right.
My suggestion, forget the piano hinge, I find them a pain, plus you still need brackets. Get a pair of folding shelf brackets from Rockler, part no. 65806. they are rated at 750 lb. a pair, open and fold up easy. Have been using them for a chop saw mount on my trailer for over a year, even cutting the heavy ends of 10' 6x6's (as opposed to cutting the light end) and they stand up. They are 16" long but will carry a 24" deep shelf nicely. I've also ordered them through ACE hardware.
Let's not confuse the issue with facts!
I have a different way to go.... This is someone that might have arthritis, and probably is kind of on the weak side.
Here is a bad drawing of one I did for my grandmother.
The magnetic catch is just to make sure that the shelf doesn't come crashing down. It doesn't have to be very strong
There is about 2 ounces of lift required to put the self back in this position. This is to make sure the shelf doesn't spring back up by itself.
The pulley and counterweight is actualy in the wall but the next one I do it will be all exposed and just in a slot that has a door over it. The drawing doesn't say but the pulley counterweight system is actually behind the shelf in the wall.
The two legs are tapered and have some hinges installed in such a manner that they drop down when the shelf is pulled on...
Adam
Edit to try to add pic.....
edit to try to add pic... I was trying to just paste the pic in the message but I guess I will have to attach it. aaaag... no I cant do that have to post another one
Edited 4/23/2004 11:18 am ET by AdamB
Edited 4/23/2004 11:20 am ET by AdamB
ok try 3Adam
Gas springs would be another possibility.
I've always liked folding up rather than down, as it (seems) like you are building a weakness where you want strength (you don't want to collapse the table surface in use, but it has to be easy to collapse).
I'd use butt hinges over the piano hinge, if only for whoever comes along later to fix/repair/renovate the table. I agree with the idea of birch ply, too; but my first choice would be laminate-covered fir ply (same strength, but a bit less weight).
I'd use a ledger board to take the butt hinges, this will provide additional strenght at the wall connection (which might be needed if there are grandkids about, like on a rainy day). Since, you'd rather not have legs, use a traingular brace hinged to the underside of the table surface (where I would use piano hinges). That way, folding the table down lets the braces drop open by gravity (though a cleat or two on the wall would not go amiss).
Magnetic catches to hold folded are good, but a touch-latch might be better for opening the table.
Or not, just my opinion.
