Follow up to question about radiant floor heating above the subfloor
Instead of using plywood or any of the mixed concrete type products, could the cement board that is used for tile backing be used in this type of application? My thinking is that because it should have the same type of thermal mass as gypcrete etc., it would work. Am I off base?
You could have put this question in the original post about radiant above subfloor.
