Footer Capillary Break
dougjl | Posted in General Discussion on March 26, 2024 05:18pm
Hi,
Hope somebody can help me out. I would like to use ice and water shield as a capillary break between the footer and the CMUs. I am in the western NC mountains and the building inspector does not like the idea of anything besides mortar on top of the footer.
This is for basement walls and the walls are engineered steel reinforced walls. The mortar contribution to tensile strength has been ignored as the steel is much much stronger.
The inspector might let me use the ice and water shield based on my engineers approval but he also wants an ICC ESR for the product.
Can anyone point me toward a product that has an ICC ESR for the use of a capillary break?  Even if it isn’t the same product I would really like to have this in my build to avoid moisture issues.
Thanks,
    ct_yankee | Mar 26, 2024 05:47pm | #1
    What, besides gravity, connects your walls to the footing?
    1. dougjl | Mar 26, 2024 07:05pm | #2
      Rebar, from footer to top of wall, all cells filled with concrete
  2. catfishbacon | Mar 26, 2024 08:47pm | #3
    Throw some reinforcements in the mortar
    1. dougjl | Mar 27, 2024 07:44am | #5
      there is joint #9 reinforcement in the mortar beds 16" on center
  3. Sean_Law12 | Mar 27, 2024 06:44am | #4
    You could try checking out Grace Ice & Water Shield. They might have the ICC ESR approval you're looking for. It's smart to want to avoid moisture issues in your build, especially in a place like western NC with its climate.
  4. pkrivanec711 | Mar 29, 2024 11:59am | #6
    Try this article from Green Building Advisor that provides products to use for your specific application.
    https://www.greenbuildingadvisor.com/article/capillary-break-at-the-footing
