FOOTING DRAINS?
JDRHI | Posted in Construction Techniques on November 15, 2002 07:03am
Hey all….lookin` for some input here. I`m building a 2 1/2 story addition…bottom floor to be a garage with a 6″ slab floor sitting level with existing grade. Foundation to go down 42″ below grade. The architect is calling for footing drains. Is this even necessary? There is nothing below garage, not even a crawl space. I dont know that I`ve ever come across this situation in the past, if I did, I took for granted footings get footing drains.
J. D. Reynolds
Home Improvements
“DO IT RIGHT, DO IT ONCE”
  1. IronHelix | Nov 15, 2002 02:26pm | #1
    Does the spec call for the drains to "go to light", to a sump, or a french drain?
    ...........................Iron Helix
      JDRHI | Nov 15, 2002 04:34pm | #2
      Water routed to dry-well.J. D. Reynolds
      Home Improvements
      "DO IT RIGHT, DO IT ONCE"
  2. JohnFinn | Nov 15, 2002 08:05pm | #3
    All I can surmize is that the elevation of the building floor is at, near, or below that of the surrounding topography, and there is the possibility of water diverting and sitting at the building perimeter. Typical slab construction with trench footings does not usually incorporate drains in our region.
