Footing drains
Juan_Mornail | Posted in Code Questions on February 7, 2020 05:39pm
Would a footing drain still be required on a home with a wrap around porch? Is there any need for a similar drainage system around the parameter of the porch? Does it matter if the porch is wood or concrete? (Washington)
  1. jlyda | Feb 08, 2020 12:55am | #1
    Depends upon your region and if you have a basement. If you have a basement, definitely need around foundation walls. Water moves in crazy ways. Porch not necessary, but it wouldn’t hurt. If it’s a new build and is excavated, throw some pipe in the ground. Corrugated pipe is cheap.
  2. Scott_Johnson1986 | Feb 08, 2020 04:35pm | #2
    Around the foundation walls is a must, but you should definitely check the rules in your region online or ask a competent authority.
