For taping when does corner bead go on ?
As a wannabe home remodeler I’m ready to tape my first whole room. At what point does the corner bead get installed? I’m thinking after the tape coat? But maybe after the fill coat? I’m confused but that’s no surprise. I’ve looked in the archives a bit but did not see any posts. I will set the metal bead in durabond for the first coat. I bought the bead already but next time I will try the paper type.
Wayne
Wayne
Whenever you want.
Really, with a few precautions or tricks, whatever you want to call them-anytime.
I set all my tape with regular, real, hard, Durabond. If the corners are on, it's a great way to "lose" mud that starts to set up.
I will do ceiling corners first, lay up the corner bead after that. I crimp, so I don't do it at the seam indentations. Run the rest of the tape then.
With a banjo or other tape appliers, you'd want to set the tape prior to bead.
drywall tips
Thanks Calvin for the advice.
Wayne
Wayne
I'm not aware of any paper corner bead, metal and hard plastic/vinyl yes,
There's no reason to set the corner bead in Durabond or any bedding, it's applied directly to the drywall with no" mud".
It is either crimped (with a corner bead crimping tool) or nailed (using blued, ring shank 1 1/2" drywall nails) in place.
Paper tape has a seam or crease running down the center of the tape, this facilitates folding the paper for inside corners,typically ceiling /wall intersection, other-wise it's installed flat, in a bed of joint compound (the pre-mixed stuff in the 5-gallon buckets..it comes in a light weight or standard version , both are pre-mixed.
If your using setting type compound, powder that gets mixed with water, e.g. Durabond or E Z sand, then you should be using fiberglass mesh type tape, this is a little more difficult to use on inside corners but makes a very strong seam where it is used.
The tape is self -adhesive, so you apply it to the drywall, then put your 1st coat on. You can then use joint compound (the pre-mixed stuff) for the rest of your coats to make it easier to sand and finish.
Mud your tapered (horizontal) joints and the ceiling side of your ceiling/wall joint, then your butt joints(verticals) and the other side of the ceiling joint. Then mud your corner bead last ( setting compound for the first coat, joint compound (pre-mix) for the rest.
Good Luck!
Geoff
geoff
I'm thinking the reverse-use fibreglas mesh, better use real Durabond. I also set my paper tape and first coat the corner bead with Durabond. Hardest and best stick of all the available compounds, I feel.
If using the no-coat for outside corners, it does get set in the durabond or premix. Wonder if that is what was meant by paper for outside corner
