forced air or boiler ….
xtal_01 | Posted in Energy, Heating & Insulation on February 2, 2020 11:49am
Hey!
So, I just finished building a house … two story … 2400 sq ft each floor … 4800 total … in VT where it gets cold.
I have natural gas.
I choose a forced air furnace … sized it  … choose a 2 stage 120,000 btu unit (about 80,000 on low).
Works great … seldom ever goes to high.
So, I am now building a workshop.
3 bays isolated from each other .. 1000 sq ft each (20 x 50 each with 16 ft ceilings) .. plus an office  …. plus a 1000 sq ft loft … so about 4500 sq ft total.
Because there are now 5 distinct areas with one (the office / bathroom, so really 6 … two are much smaller than the others) … I was thinking about hot water heating.
Originally I thought just a single large furnace with zones (like I did to the house … I have three zones).
Then I thought about 3 or 4 simple single stage furnaces …one for each …but that get a bit pricey for a workshop.
Then I thought about a hot water system.  Simple enough … tankless boiler (like my hot water heater in the house) …. a bunch of PEX and a couple of ceiling hung radiators with fans in each area.
Now, here is my problem ….
I look at Home Depot … 199,000 BTUh boiler …. 9.3 gpm … 100 – 180 deg heating water.
I look at a Modine heat exchanger chart ….  HSB/HC 108 … at 9.7 GMP and 180 deg water, I am only getting out about 70,000 BTUh …why ?????
If the boiler has a 199,000 BTUh rating but using it’s full capacity I an only getting 70,000 BTUh out … what happened?????
I am a true DIY guy (thus it took 7 years to build a house) .. have put in a few furnaces (gas and electric) and A/C units … all worked great.
I have just never touched a hot water boiler before.
If I can get the full boiler heat out of the exchangers, I would have no problem … but less than half will never heat the building.
Can anyone explain what is going on or if I am making some kind of mistake reading the tables.
Thanks  so much …. Mike
  • A Postwar Comeback
